Skyline Supposedly Involved In Robbery This Morning...
Vu, Damo, Bunny, Troy, Ryan.............and anyone else I missed out there..........expect a visit
Cool !!!!! santa is coming to town, and I thought he was a farce? lol mum was lying to us kids Santa exist's Pete said so..lol My list is long Santa,Hi Flowed turbo, Intercooler,NOS,a hot chick for shotgun ...lol
Hey dont forget Cara. ? but is her car white still ? or decal colour..lol (just kidding so put your guns away Cara)
after todays drive to the city, I had every cop look me over but didnt do anything to entice them to look further ? guess Us old guys (Pete, Midlife, myself) dont attract the SAPOL as much ?
and what the hell is a skyline out at that time in the morning on Wed? paper boy ? Milk man? coming back from the OTHER womens bed ?lol
shift worker or up to NO GOOD?
hope they string them up by the jewels for it. bastards. anti carjacking alarm ? works a charm for these idiots
  • Replies 49
thats pretty farked, not good to hear, guys should be drawn and quartered for shit like that.
another loss for the northern suburbs
another useful post, your input is greatly appreciated.
on the plus side its good criminals are no longer into racism with a caucasion teaming up wit an asian unstopable duo
:bunny: :bunny: :bunny:
yay for more police attention being shown to imports...
FYI here's the media release from SAPOL:
Robbery - Paralowie
Elizabeth Police are searching for two men who allegedly robbed a
man at gunpoint in the early hours of this morning. At about 4.30 am,
the victim was in his car, stopped at the intersection of Kings Road
and Fairbanks Drive, Paralowie, when he was approached by the two
men. One of the men smashed the victim's windscreen with an iron
bar, while the other, armed with a dark coloured handgun, demanded
money. They stole the victim's wallet, containing an amount of cash
and left in a white Nissan skyline. The victim received minor injuries
in the robbery but did not require hospital treatment. The suspects
are described as one being of Caucasian appearance, 175 cm tall,
AUTHORISED BY Sergeant Astrid Gustavson, Acting Officer in Charge Media Section
MEDIA OFFICER Senior Constable First Class Rebecca Stokes
MEDIA SECTION TELEPHONE 8226 2688 FACSIMILE 8463 3723
www.police.sa.gov.au South Australia Police, GPO Box 1539, Adelaide SA 5001 ABN 93 799 021 552
thick set, and about 90 kg. The other man is of Asian appearance,
172 cm tall, slim build and weighs about 65 kg. Both are aged in their
late 20s and were wearing dark clothing and dark hoodie jumpers.
Police are keen to speak with anyone who may have seen these two
men or has any information about this robbery. Please call BankSA
Crime Stoppers on 1800 333 000.
From: http://www.sapolice.sa.gov.au/utils/html_v...amp;str=skyline
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
