So i have removed the spoiler from my 34, and am planning on having the holes filled in and getting it re-sprayed, the question is, do i have the holes welded or is it ok to have the fibreglassed/bogged
also what problems could occur from having it fibreglassed/bogged as i know welding them would be the ideal option
there are 6 small holes on the top of the lid, but im also removing the tail light in the centre, so that is a bit larger of a hole.
advice much appreciated
steve
The normal method is to mash bog in the holes then put bog on tape, put the tape over the hole so the bog doesn’t fall down
Then peel the tape off and its "fixed"
Welding its generally the best method but if you don't do it well you can warp the boot…
Its also expensive
Oh and the shortcut way is just buy rubber plugs and plug up the holes...
yeah, well right now, if i go the fibreglass/bog method, i can have it all done for free, but im just wondering if there are any complications with it, like it warping or popping out of the hole and so forth, even over time
weld it, best option for a permanant solution.
glassing can work, BUT you cant really get in behind it to get a good adhesion to the surface due to the support framing
bog will eventually crack off as you flex the boot to open and close it.
welding it up can't be that expensive .. it's just a bunch of tiny holes ?? I can't imagine it taking a panel beater more than 10-15 mins. And if you decide to put it back on, just drill through.
I'm actually thinking of doing the same to my GTT once the body kit goes on next week .. I'll see what it looks like first when I take the wing off (is it hard to take it off?) Cool thing is, Justcar have arranged for me to get this done for free (ie. boot welded up/painted) if I want to instead of getting my factory rear bar painted after a recent fender bender.
Edited by Delta Force
^^^ so your an expert..
and Craved, i tried the kitty hair.. however the kitty wasnt too happy when i started pulling out his hair.. so beware that this method involves alot of cuts & scratches :banana:
Be prepared for doing the rear wing, what you have to do is as follows
1. Remove boot lining on the bootlid (simple enough just a tonne of little twisty clips)
2. Unscrew the 2 bolts for each side of the wing from inside the boot (dont worry the wing will not fall off once both are undone so you don't need to hold it whilst unscrewing)
3. Next you should close the bootlid and begin applying a little pressure from under the wing, pushing upwards to expose the glue holding the wing to the bootlid.
Whilst holding the wing up (maybe only 2-5mm, this helps to have another set of hands for) use a thin stanley knife (or any retractable knife that you can extend a little) to cut along the glue.
(there is a lot of glue under each side of the wing, so take your time and go around the base slowly.
4. Once all of the glue is cut, open the bootlid again and push the wing upward again slightly whilst squeezing the clip under each side of the wing (in between where the 2 bolts were for each side)
The wing should pop out quite easily and hey presto, you just removed the wing from your 34!!
Hope this helps,
On Topic, i think im going to get it fibreglassed, if worse comes to worse and it warps or cracks in a few years, ill get a new bootlid or have it patched, ill trust the person im having do it to do a good job on it.
and Craved, i tried the kitty hair.. however the kitty wasnt too happy when i started pulling out his hair.. so beware that this method involves alot of cuts & scratches :laugh:
dude?
what ever you do, dont fibreglass the holes,
weld is the way to go.
fibreglass, will look good for abit, but as times come it will sink, my boot holes have been filled but have sunk because of the fibreglass..
pay a little extra for the weld, and you will get a better boot that wont sink or crack (meaning you will have to paint the whole boot again when they patch it up again).
my 2c, I've learnt my lesson.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
