Thanks guys for all the information on the forum. ( I used a lot the SEARCH button)
I am very happy with the performance of our GTR R33. First day at the 1/4 mile track we run 4 passes 11.4, 11.0, 10.82 and 10.61
We run with SUNOCO Race Fuels GT PLus 104 octane unleaded.
The car is a single turbo power FC +600whp tunned by Cristian Penson @
C-WORKS shop sponsored by Zero Wheels and omegaxenon.com
And after the first visit to the track it become the fastest Nissan in Dominican Republic.
We look foward for better times on 2009. :banana:
https://www.sau.com.au/forums/topic/249485-1061-14-mile-first-day-at-track/
440rwkw will throw you deeper mate, keep the R&D going with that power as there is still faster ET's to be had!
Great work!
What turbo/tyres outta interest?
Im guessing GT35 if your running 104, a a T04Z should do that on 98 (whever the equiv is over there)
Great work!
The car makes 600whp on a 4 wheel dyno.
Borg Warner S300 series single turbo conversion.
4 slicks tires 26"
Edited by 95GTR600
what are your 60ft time on slicks?
440rwkw has seen very low 10s on semi's, not full slicks...
Get that 60ft down (which is where i expect your loosing the time) and see a 9 without a doubt on slicks
first 1.59
best 1.50
There is an easy gain if you can grab second before you hit limiter.. sounds like it bounced of it at least 2 times.. thats gotta be worth .1 of a second. Keep up the good work! Out of curiosity, whats your response like with that turbo compared to say, a Garret t04z which is in the same power range.
You are right, it was my first time running a RHD car... but I agree with you about hit limiter.
I love the Borg Wagner turbo...a friend has one Honda producing 800whp @ 36 lbs of boost.
We got full boost at 5,200rpms.
We will try to make things better next time.
Edited by 95GTR600
What should be a decent 0-60 ft ?
Do you think factory rear differential will hold the power ?
Nice work, is it S362 or bigger? Going by that dyno power and trap speed I am guessing it was tuned on a hub dyno or something?
it's a S372 with a S400 label. I did not understand well about it. But I am very happy with the turbo and the whole car.
We look foward for better times when the track is open again.
Does anyone knows what we have to do in order to make 1.3x on 0-60f with slicks ? Which way to do a good burn out without damage the case, etc. ?
Edited by 95GTR600
Damn mate thats a big turbo you have there, and pretty good spool for a turbo of that size too - probably got more in it :D
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
