I bought them for last year as I was doing ridiculous kays in my car. In short, no. They're not very good. They tend to wear reasonably well but if you want a performance tyre, look elsewhere.
They do smoke up quite well though :D
Adrian
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-530959
I'm on my second set, and I only replaced the first because I was concerned how they would go in a RWC.
I've got good mileage out of them (20k+), including some time on the race track (club sprints only). They don't like being caned (as on the track), but as a general on-road high performance tyre, I've yet to fault them.
They're probably not as good overall as Bridgie 520s or whatever those Bridgies are on the HSVs, but those Bridgies are not twice as good (I think they cost about twice as much).
A good bang-for-your-buck performance tyre, IMHO.
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-531225
i have falken ze502's on the rear of mine. they have some nice grip, but wear quite quickly - ive only gotten 10,000k's outa mine :) and they cost 320 each aswell :)
back to topic : i havent heard anything about these tyres gloof
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-531408
That's cheap for ZE-326. I remember when I got mine they were like $180. For the price you pay for them, they are pretty good. As everyone said, not much grip when launching but alright for just street tyres.
The good thing is that these tyres are none directional so I can swap my tyres without been refited when it start wearing out on the inside shoulder. Hasn't happen yet but on my old tyres my front were wearing on the inside shoulder.
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-537144
You will still have to refit them. Otherwise, if you just swap the wheels, you'll have the tyre on the other side of the car, turning the other way, but still wearing the inside. :burnout:
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-539638
Yeah that's what I mean swaping wheels altogether, so would be inside out with the wore shoulder outside and the better shoulder inside. This would balance it out abit. And when the inside start wearing again, i'll swap it again hehehe.
Don't know how many time I'll be able to swap them around for haha.
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-541579
They're reasonable all around tyres for the price.. So if that is what you're after, go for it. If you're doing heaps of burnouts or mucking around probably going to be fine for that.
Meant to have greater life than the ze502's, but less grip. Nothing terrible, but they only gave me a bit more traction than my old Simex I think :D
Personally, while i bought those tyres due to recommendations on here - i'd try something different. They are cheap though :(
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-545975
Hi, I've got some Falken ZE -502(205/55/16) on My R32 gts4 had them since April
got them from quickfit for $600 for set fit&bal. They are ok, but squeal easier then than the BFGoodrich radial TA's i had before.
The Falkens are better steering tires than the goodriches but have less traction than goodriches on the rears.i.e. going around small roundabouts in the wet, falkens hold line, goodriches run wide-understeer! like crazy.
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-550110
What speed rating are the ST115? I had a look at the American site and some seemed to be V or W rated, but most had no speed rating listed at all. And what does Treadwear 360, Traction A, and Temperature A mean?
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-550670
well, treadwear is a comparative number for how long the tyre will last, not sure about what the scale is tho. traction and temperature I'm not sure about
.....it would be great if we could get a tyre expert on these forums :)
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-556118
I think the ST115's are softer than the ZE326's, which would mean that the higher the number, the softer it is? My girlfriend's Nankang EX601's have a treadwear of 320, and they last a pretty long time. I can't imagine the ST115's lasting any longer than that.
https://www.sau.com.au/forums/topic/24979-falken-ze326/#findComment-556280
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
