for sale rb30e series 1 block with all internals minus everything on outside $75 perfect for 25/30 conversion
for sale rb30et head $50
pics up soon just want it all gone
or will swap for parts of interest let me know what you have got
Edited by Turbo 33
https://www.sau.com.au/forums/topic/249856-rb30/
where abouts in brisbane are you?
also do u know details of the block? i.e k's, what car it came form, when was the head removed etc
pm sent
southside
i will find out k's
came from vl
head was removed a little over 6 months ago a mate was going to do a turbo conversion to it but never got around to it
https://www.sau.com.au/forums/topic/249856-rb30/#findComment-4331652
will swap for r33 gtst parts like steering shroud,
the plastic bits the go from roof to floor in the middle of the car
all boot trim
parcel shelf
drivers side door trim and passenger side
handbrake rubber thing gearstick boot gear stick plastic
pretty much any interior parts let me know what you have and we can work something out
clear side indicators or smoked ones
turbo timer
Edited by Turbo 33
https://www.sau.com.au/forums/topic/249856-rb30/#findComment-4331730
bump want it gone
all boot trim
parcel shelf
turbo timer
https://www.sau.com.au/forums/topic/249856-rb30/#findComment-4336948
ahhh boo mate, thought you were going to do something cool with it.
shane it was the one i had lying around - gave it to josh for free.
no i still have that this is one i brought off a mate about 2-3 months before you gave me that one this one is a series one block
Edited by Turbo 33
https://www.sau.com.au/forums/topic/249856-rb30/#findComment-4344760
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
