  • Replies 2.5k
Posted Images
Doubt it, they are getting all the recognition without spending a dime.
I doubt that, Ross Brawn and now Richard Branson are getting the recognition, I agree.. Those within Honda are going to be pissed atm, and those in the sport now realise that Honda could've been a potent force this year, however, they aren't in it, so they can't win it... Go Brawn, Button & Barrichello!!
My thoughts exactly there... There ain't any Honda markings on the car any more so nothing for honda.
Also its a Brawn car with a Mclaren engine... Nothing for honda to take the credit for at all
Edited by bnr#@
BUMB ASS Honda. Hell they are still throwing money at the team, yet Brawn, Virgin and Mercedes are now getting all the credit. LOL, that has to hurt :D Especially after all those years of uber money and one lucky win.
But Webz, did anybody see qualifying? Webz is nowehere and Vettel did what a lot of people said he would do to Webber :D Oh well, hopefully Rubens can knock off Button and Vettel can do good for RBR.
Personally i think its GREAT to see Mclaren down the back and Ferrari mid field and BMW/Renault struggling. Good for the series, just dont let Button win...please. Not another POM!
Bet honda is pretty pissed about selling the team right about now....
They sold the team, Brawn GP changed engines, now they're at the front...Honda has nothing to do with it essentially...
If the diffusers are deemed illegal, I'd say they'll be back to a midfield team for a while at least...
Weights at end of qualifying:
1.Jenson Button 664kg
2.Rubens Barrichello 666
3.Sebastian Vettel 657
4.Robert Kubica 650
5.Nico Rosberg 657
6.Felipe Massa 654
7.Kimi Raikkonen 655
8.Mark Webber 662
9.Nick Heidfeld 691
10.Fernando Alonso 680
11.Heikki Kovalainen 690
12.Nelson Piquet 694
13.Giancarlo Fisichella 689
14.Kazuki Nakajima 612
15.Sebastien Buemi 675
16.Adrian Sutil 684
17.Sebastien Bourdais 662
18.Lewis Hamilton 655
19.Timo Glock 670
20.Jarno Trulli 655
they should try the same with Ferrari- those dopey outboard rearview mirrors on posts are surely part of the aero package, and they flex and wobble like a mofo! lol
Nakajima won't be out long...
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
