  • Replies 2.5k
Posted Images
Doubt it, they are getting all the recognition without spending a dime.
I doubt that, Ross Brawn and now Richard Branson are getting the recognition, I agree.. Those within Honda are going to be pissed atm, and those in the sport now realise that Honda could've been a potent force this year, however, they aren't in it, so they can't win it... Go Brawn, Button & Barrichello!!
My thoughts exactly there... There ain't any Honda markings on the car any more so nothing for honda.
Also its a Brawn car with a Mclaren engine... Nothing for honda to take the credit for at all
Edited by bnr#@
BUMB ASS Honda. Hell they are still throwing money at the team, yet Brawn, Virgin and Mercedes are now getting all the credit. LOL, that has to hurt :D Especially after all those years of uber money and one lucky win.
But Webz, did anybody see qualifying? Webz is nowehere and Vettel did what a lot of people said he would do to Webber :D Oh well, hopefully Rubens can knock off Button and Vettel can do good for RBR.
Personally i think its GREAT to see Mclaren down the back and Ferrari mid field and BMW/Renault struggling. Good for the series, just dont let Button win...please. Not another POM!
Bet honda is pretty pissed about selling the team right about now....
They sold the team, Brawn GP changed engines, now they're at the front...Honda has nothing to do with it essentially...
If the diffusers are deemed illegal, I'd say they'll be back to a midfield team for a while at least...
Weights at end of qualifying:
1.Jenson Button 664kg
2.Rubens Barrichello 666
3.Sebastian Vettel 657
4.Robert Kubica 650
5.Nico Rosberg 657
6.Felipe Massa 654
7.Kimi Raikkonen 655
8.Mark Webber 662
9.Nick Heidfeld 691
10.Fernando Alonso 680
11.Heikki Kovalainen 690
12.Nelson Piquet 694
13.Giancarlo Fisichella 689
14.Kazuki Nakajima 612
15.Sebastien Buemi 675
16.Adrian Sutil 684
17.Sebastien Bourdais 662
18.Lewis Hamilton 655
19.Timo Glock 670
20.Jarno Trulli 655
they should try the same with Ferrari- those dopey outboard rearview mirrors on posts are surely part of the aero package, and they flex and wobble like a mofo! lol
Nakajima won't be out long...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
