  • Replies 2.5k
Posted Images
You get the one-eyed cocks that understand zilch about F1, but follow Ferrari because they are either stupid wogs that don't know better or can't be rooted supporting anyone else. There are those that have a vauge understanding of F1 history, that begins in roughly 2000, never bothering to look back past beyond the Schumacher years, many wouldn't have the first clue that he also drove for Benneton or Jordan. Some that are very knowledgable about F1, but like the Collingwood supporter, will always hiss and cruse when the FIA go against them (Which is rare these days) and bag everyone else for being either crap, cheaters or just plain incompetant.
In all honesty what hope have they got when, for example, a certain multiple championship winning Ferrari driver (hint it was Michael Schumacher) in all seriousness once asked whether him & Irvine locking out the front row of the grid was the first time it ever happened for Ferrari?
It always used to sh1t me to hear Murray Walker banging on about how everyone in the race did such a wonderful job. But the longer I follow the sport the more I realise he had a point.
Anyway Ferrari aren't going anywhere. Nor, as far as I know, are anyone else.
Maybe a bit like the revolution is just a t-shirt away, P1 is about an hour away?
Very interesting practice session, both Ferrari's in the top 5..... Vettel faster than Webber and wtf, Piquet went faster than Alonso!!
Truth will be told however in qualifying later tonight where no one can hide from the scales.... :D
Edited by TALBO
Well he has the opportunity to still get points, just have to hope that he shows the same agressive overtaking he demonstrated in Malaysia. Q3 looks interesting.
Oh yeh...and FAARK SUTIL! That hack couldnt stop spinning last weekend, he binned it when he found himself in the position of having made less mistakes then all the other people in the midfield who had tripped over one another....and now not happy enough with writing his own race weekend off with binning it wants to baulk cars on quali laps!! FARK!
But why is it Mark didnt even get a banker lap in to ensure Q2... Mark makes his life difficult at times
I just saw the qualifying results and was wondering wtf happened to webber. That's pretty much farked up the race then hasn't it lol.
Go vettel now I guess. As long as Hamilton or Alonso don't win I'll be happy :/
Vettel looks like he is on track for another win. Hamilton might get off the line quite well and he is a genuine chance with KERS of grabbing a spot or two from the start.
1. Jarno Trulli, Toyota, 648.5 kg
2. Timo Glock, Toyota, 643
3. Sebastian Vettel, Red Bull, 659
4. Jenson Button, Brawn GP, 652.5
5. Lewis Hamilton, McLaren, 652.5
6. Rubens Barrichello, Brawn GP, 649
7. Fernando Alonso, Renault, 650.5
8. Felipe Massa, Ferrari, 664.5
9. Nico Rosberg, Williams, 670.5
10. Kimi Raikkonen, Ferrari, 671.5
11. Heikki Kovalainen, McLaren, 678.5
12. Kazuki Nakajima, Williams, 680.9
13. Robert Kubica, BMW Sauber, 698.6
14. Nick Heidfeld, BMW Sauber, 696.3
15. Nelson Piquet, Renault, 677.6
16. Sebastien Buemi, Toro Rosso, 678.5
17. Giancarlo Fisichella, Force India, 652
18. Mark Webber, Red Bull, 656
19. Adrian Sutil, Force India, 679
20. Sebastien Bourdais, Toro Rosso, 667.5
Edited by wolverine
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
