  • Replies 2.5k
Posted Images
Pos Driver Weight (kg)
1. Alonso Renault 637.5. Should Pitt roughly lap 13/14
2. Vettel Red Bull-Renault 655.0. Lap 20
3. Webber Red Bull-Renault 652.0. Lap 18/19
4. Hamilton McLaren-Mercedes 650.5. Lap 18
5. Rosberg Williams-Toyota 654.0. Lap 19/20
6. Kovalainen McLaren-Mercedes 655.5. Lap 20
7. Raikkonen Ferrari 651.5. Lap 18/19
8. Button Brawn-Mercedes 664.5. Lap 23/24
9. Nakajima Williams-Toyota 658.0. Lap 21
10. Massa Ferrari
11. Buemi Toro Rosso-Ferrari 671.5
12. Trulli Toyota 671.3
13. Barrichello Brawn-Mercedes 689.0
14. Glock Toyota 679.2
15. Piquet Renault 667.7
16. Heidfeld BMW-Sauber 658.0
17. Fisichella Force India-Mercedes 680.5
18. Sutil Force India-Mercedes 683.5
19. Kubica BMW-Sauber 666.0
20. Alguersuari Toro Rosso-Ferrari 675.5
stolen from autosport.com
Alonso has gone light and aggressive, button running heavy looks like tomorrow might be very interesting although I'm hoping for another red bull 1-2 I feel buttons got a chance of getting decent points this time.
I also did a rough estimate of when they should Pitt for fuel, but ofcourse you can never be too sure they may switch strategies or it might rain.
Edited by DaGr81
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
