  • Replies 2.5k
Posted Images
I thought Rubens "Can I Catch Him?" was the comment of the race
yeah the reply of.... "ummm no, your in the same situation as him" shut that down. what they should have said was simply....... "LOL".
and webber was robbed. that move on alonso was hunky dory. I can't believe he had to let gonzo and glock past and dropped 8 seconds doing it. look where glock finished..... second. and with zero passing that position had webbers name on it. never mind that his brakes exploded.... :D
now I know why webber was 11:1 for the win and also why I must have been the only bloke with money on him. vettel was 5:1 and homoton was a staggering 1.75:1 which in hindsight seems about right.... :(
and with zero passing that position had webbers name on it. never mind that his brakes exploded.... :P
Webber could well win the Most Spectacular Mechanical Failure Of The Season award (Alonso's wheel departure was more of a pit crew failure). He's lucky it happened on pretty much the only part of the track with decent run-off...
Still gutted that the Monza Fence Tester won the GP!
awwww :'(
Man some of you Webber lovers just can't get past the fact that rules are rules. Niko also broke the rules and had to pay a penalty!
But rules work better when they are applied with some consistency :D
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
