  • Replies 2.5k
Posted Images
Agree, he has been awesome in his first two races. Showing more promise then all the other GP2 hacks that have arrived in F1 this year.
(Oh, and waiting to hear back froma friend to pick up the seats from you)
No problemo, they're not going anywhere.
Well, here on UK tv they are saying Press Release in 60minutes confirming Toyota withdrawl :( I wanted to see them hang around, so many new teams next year...its going to be a circus nxt year with Lotus, Manor, USF1 and all these fresh fish :D
Their new boy has some promise and i wanted to see the guy give it a go next year. I cant believe, Honda, Toyota and BMW are not even interested in hanging around as engine suppliers :) Toyota should just throw their money an resources at Williams and let Frank & Patrick do their thing :D
Nakajima wasnt too bad, he was better then most of the GP2 hacks that have come through of late. Kobayashi (Spelling?) had real promise and i would like to see the guy back.
I read somewhere that Sato was in with a chance at Lotus?!?!?! Like i said, all these new teams, its laughable that they are coming in with old has been drivers, no testing, no budget, no manufacturer support or even engine deals. Its going to be a circus next year with so much carnage and mechanical failures....its back to the 90s :(
Toyota 'set to leave Formula 1'
Toyota is to hold a press conference at 0800 GMT on Wednesday amid reports that it is to quit Formula 1.
Japanese media claims that the world's largest car manufacturer is set to leave F1 in an attempt to cut costs.
Williams announced last week that it would be replacing its Toyota engine with a Cosworth for next season.
Toyota has not won a grand prix since making its F1 debut in 2002 and finished fifth in the constructor championship this season.
Long-term Toyota driver Jarno Trulli was second in last month's Japanese Grand Prix, equalling the team's best finish to a race, which they achieved on four other occasions.
Japanese driver Kamui Kobayashi joined Trulli for the final two races of the season after regular driver Timo Glock was injured.
Germany's Ralf Schumacher, France's Olivier Panis and Britain's Allan McNish have also all driven for Toyota over the years.
Honda and BMW have already left F1 and Toyota's withdrawal would leave the sport with no Japanese team.
Japanese tyre firm Bridgestone announced on Monday that it would not be renewing its contract to supply F1 after its current deal runs out at the end of the 2010 season.
Edited by ctjet
The real question is if the Concorde agreement means nothing to Toyota then i am not convinced that Renault are not for sale to the likes of Prodrive-Richards etc. Irrespective of signing Kubica, the team is up against it in a time where it has less money then Honda, BMW and Toyota, their prospects for next season are grim with a poor car, new drivers and losses in engineering departments.
So, what are the odds if Toyota do call it quits in 10minutes time that Renault will also hand over the team to the likes of Prodrive????
Heidfeld's been cited as a possibility for McLaren next year if the Raikkonen thing doesn't happen. Suits me; He seems to be Mr Consistency, and could even be up the pointy end on a regular basis with a better car. I'm sure Mercedes would love working the German driver angle, too.
Lewis scoring podiums + Nick finishing well into the points all season = WCC trophy :)
McLaren washed their hands of Heidfeld years ago and Kimi wants a seat. Kimi will be at McLaren before Heidfeld. i think they would be chasing Rosberg, Sutil, Glock and Heiki before they go Heidfeld, but nothing would surprise me.
I still cant see why Rosberg would chose Brawn over McLaren....and i cant see how Rosberg isnt the best pic on the market after Kimi so McLaren have some good options before going to Heidfeld
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
