My RB20 has been throwing out fault code 13: temp sensor, so ive replaced the sensor but it still throws the code out, i have got ground and 9v feed from ECU?
any ideas what else to do?
cars running rch as, O2 is sayn lean, so ecus pumpn more fuel in, temp sensors not readn proper temp, car drives like crap hit boost and it bogs down no power, and it spluters and crap
post away and ideas or past problems you guys have had.
Thanks Damo
https://www.sau.com.au/forums/topic/250165-rb20det-fault-code-13/
with the temp sensor not working, the ecu will be stuck in cold temp corrrection, thats is, retard mode
so until you fix that, theres not point loading it up or bring it on boost, in fact, its probably doing harm as the correction is sucky
there are two sensors for water, one for the cluster and one for the ecu, i would suggest replacing both with known working items
the ecu doesnt pump more or less fuel in based on the 02 sensor in real time, its a minute correction on light cruise
so be seeing rich or lean from the ecu diag, means nothing, provides nothing useful and will just add confusion or misleading information
fix the water temp sensor, your problems will go away
the part should be a generic nissan item from most auto workshops, undo the item, take it into the shop
and ask for a replacement one basicaly. my r33 rb25 has an 180sx water temp sensor it and it works fine
ie: its a generic nissan part, not an RBxx model specific one so you can mix match providing plug and voltage/scale is the same
Yeh i have replaced the sensor but still no deal, Code 13 is temp sensor or wiring circuit fault.
But i have checked theses earth and a volt reading, but the volt reading from ECU is higher then it should be, should be around 5volts but im getn a reading of around 9volts i think.
Im going to wiring up a better earth and hope that fixs it, but other then that im stumd, cant be ecu fault surely workd fine on old engine.
next step is taking it to a shop some day.
My 20 is still giving me tha sh!ts, looking for another RB20DET ECU, any one got one for sale.
only thing left i xcan think of to try and fix this Temp sensor fault, replaced sensor, check loom eveythings works out within specs, exspect for 9volt output when it should have 5volt, so ecu might be fokd
you sure u replaced the ecu sensor, it has 2 wires goin to it.
Yeh replaced tha right sensor,
also cleared code using snapon scanner, just relogs striaght away,
swaped ecus but used a ceffy one, can drove good, bit rich but boosted normel, only thing is got told cant used other ecus need to match what loom and sensors you got?
ive been running a r32 ecu coz im sure i got a r32 loom, does any one no how to tell the looms apart?
also after a R32 ECU?
Thanks Damo
All fixed, tonight i ended up running to new wires from CTS in tho cabin and cut old wires from ECU and joined new ones in, No more temp sensor faults, so must had a bad wire, or broken wire,
Hope the fault says away now.
Thanks for your help
Damo
Not strictly true.. My RB20 and my mates RB26 head had yellow sensors. When I built my 30 I accidentally snapped my RB20 temp sensor so had to use the BROWN temp sensor that came with my RB25DE head.. ecu thought it was in cold start ALL THE TIME until I put my mates yellow RB26 sensor in there..
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
