  • Replies 63
Track 1 (closer) on Kings of Leon's only by the night, can't stop playing it at the mo.
Anything such as Suicidal Tendancies, Audioslave, Aussie Crawl, Pennywise, Helmet, depends on what mood i'm in really.
Depends the mood, cruizing is nice with jamiroquay(cool)...when going around the city(full o'jercks)metallica/infectious grooves...but some electronic music is no bad .
The bloke that sold me the car put the cheapest radio in it,lucky it has audio input,so i hook up my mp3 player...
ITS GOTTA BE METAL MOTHER F*#KER AND PLAY IT LOUD GRRRRR I think I'm one of the only skyline owners around that wont listen to doof doof cant stand it. The plus side is it get your blood pumpin and makes you wont to go hard HELL YEAH!!!!! :D
ITS GOTTA BE METAL MOTHER F*#KER AND PLAY IT LOUD GRRRRR I think I'm one of the only skyline owners around that wont listen to doof doof cant stand it. The plus side is it get your blood pumpin and makes you wont to go hard HELL YEAH!!!!! :(
LOL!
You, me, Evil, CAJFLY, evade, SNISMO and looks like southern tango are all the Metal Head bangers atm in the tread. ;)
for daily drive to and from work RnB and somtimes house and i little hip hop. alone time driving around hip hop with the occasional trance hard style stuff here and there. while on a cruise listen to the car unless its a long ass cruise then ill go with the mood but it always comes back to me going back to hiip hop. bit of 2 pac here and there and snoopy lol
LOL!
You, me, Evil, CAJFLY, evade, SNISMO and looks like southern tango are all the Metal Head bangers atm in the tread. :blink:
:blush:
I love to get the metal pumping, a bit of Parkway Drive or I Killed the Prom Queen always goes alright.
I do get some strange looks tho haha.
im talking more like
in flames
at the gates
children of bodom
arsis
opeth
insomnium
dimmu borgir
anata
heaven shall burn
some arch enemy if im in the mood..
austrian death machine and dethklok is a laugh too..
if you're looking to hear some of this shit ill give you some song names and you can run off and have a listen..
*ahhah just noticed someone else mentioned austrian death machine in a few posts pack..get to the choppa, screw you (benny) and come with me if you want to live are standouts for me..so good.
For sure man!
Also HER NIGHTMARE FTW!
in flames
at the gates
children of bodom
arsis
opeth
insomnium
dimmu borgir
anata
heaven shall burn
Just got Heaven Shall Burns new album. Friggin awesome!
Also to name afew more, August Burns Red, Walls Of Jericho, Pantera and Cannibal Corpse. :D;)
LOL!
:D
Is that so?
Machine Head, Pantera, Metallica (old obviously), Tool, Disturbed, Slayer, Black Tide are part of my ipod playlist atm...
Edited by iamhe77
For sure man!
Also to name afew more, August Burns Red, Walls Of Jericho, Pantera and Cannibal Corpse. :D:P
Ahh yes Her Nightmare, cant forget The Daylight Curse either! xd
Oh and Heaven Shall Burn + Caliban = german metal FTW! :ermm:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
