Hey dudes. I picked up another R33 thats just asking to be parted out. it was hit up the arse on the right hand side so the front end is still good.. the rear quarter, right tail light, bootlid and rear bumper are gone though. More pics will be added in the next few days - Pm me for anything specific
R33 Series 2 motor:
Approx 85,000 ks, great compression- 155/160psi across all cyls. Includes turbo & wiring loom - $1800 ono
4sp Auto gearbox - $500
Front end stuff:
S2 front bar -SOLD
S2 grille -SOLD
Front guards - $100 each
S2 headlights - $500 firm pair
S2 bonnet - $300
A/c fan - $80
A/c condenser - $150
Radiator & shroud - $100
Front reo bar (uncut) - $150
Radiator support - $150
Engine bay stuff:
S2 AFM (pink sticker)- $90
R33 aircon compressor - $100
R33 power steering pump - $100
R33 alternator - $80
Fuse box lid - $20
Stock cat converter - $50
Washer bottle - $20
Radiator overflow bottle - $20
Charcoal canister - $30
Stock airbox & snorkel + filter - $80
Stock SMIC piping - $50
Stock sidemount intercooler - $40
ABS pump - $100
Exterior & suspension/brakes:
Set of R33 gts-t stockies with kuhmo tyres. almost brand new / 90% tread - $300
5 stud space saver - $50
Side mirrors - $50 each
Tail light (left hand side) - $50
Rear SKYLINE garnish (silver) - $50
Bm-44 ABS brake master cylinder - $80
Stock suspension, complete set - $200
Front lower control arms - $60 each
Front upper control arms - $40 each
Front hubs - $80 ea
Rear lower control arms - $60 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
Auto ABS 4.3 diff - SOLD
Driveshafts $60 pair
Rear upper arms - $50
Front calipers - SOLD
front rotors (almost brand new) - $50
rear calipers - $150 pair
Rear rotors (almost brand new) - $50
Interior stuff:
Drivers door window switch - $80
Drivers window switch surround - $40
Drivers door motor - $80
Passenger door motor - $50
Door trims - $50 each
S2 Dash surround (with clock, hazard switch etc) - $80
Instrument cluster (auto) ~85,000ks - $100
Auto gear stick surround - $40
Under dash piece (covers fuse box) $30
S2 dash pad (with passenger airbag & panel) - $400
S2 Steering wheel with airbag - $250
Centre console - $60
Front seats, good condition - $200
Rear seats, good condition - $50
Seatbelts, full set - $80 (will seperate)
Ignition barrel + door barrels + key - $100
If theres any stuff not listed send me a PM and i'll get back to ya. Located in sydney for pickup or I can post almost anything at buyers expense :D
  • Replies 56
Posted Images
Hey mate, interested in the throttle body + cable.
cheers
Pm sent
hey mate im interested in the whole engine.
how many ks has it got?
pm me back
cheers
it's got 85000 ks, Pm sent
hi mate can i get some pictures of the rims... thanks
yep, PM sent
PM sent mate
Pm replied
Few bits are sold:
front bar, headlights, front reo bar, left guard, grille, front rotors, front calipers & diff
hey mate ur inbox is full haha
ok ok thats all sweet mate
didnt hurt asking tho.
i have another bloke trying to sell me a whole rb25det engine without loom n ecu also for 1800 i offered him also 1400 and he took it
only thing stopping me from buying his is hes taking the inlet manifold off not hard to put back on but i cant be stuffed doing it lol.and also he cant give me a better description of the comp results..
so would u consider 1400 as a deal for the whole engine or wat?
because ill go grab sum monies together and buy it from u..
i think ive bought from u b4 lol
Hey mate...keen on..
If still available...Im in brisbane, so can ya also get us a figure for postage if possible thanks mate!
Do u still got the accelerator cable?
Sorry mate it's sold
Pm sent
How about the glove box there's 2 clips which hold the glove box into place and allow it to move I'm after those 2 pm me ta
sorry mate I want to keep all the clips and stuff together with the glovebox. if you're keen on the whole thing PM me :action-smiley-069:
PM sent
Pm replied!
no worries, Pm sent
few more bits sold:
Drivers side window motor, stock wheels, seats front/back, steering wheel, drv window switch surround
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
