  • Replies 124
The BOV was tightened right up and works fine. It hasn't got a gates timing belt. The rubbing noise went away as soon as you loosened the front bolts. It ide's fine and revs at idle with no problem (except for it backfiring when you take your foot off and the revs fall back to idle. No blue smoke at all. What 3 cam timing marks are you talking about? One option i thought is to pull the cam out and get a CAS that has the key in it. and get a cam that has the opposite key. Just so i know thats fine. But im guessing thats alot of work if it's not going to fix the problem.
they key in the cam just makes it easyer to line up the timing no need to change but when putting the CAS you have to take extra care in making sure its in the right position
But if the timing was ligned up at the 0 mark on the crank with a timing light wouldn't that say that the CAS is working fine and the cam is in the right spot? And how do you know exactly what point to put the CAS in?
The workshop is very unlikely to lend you their tools and hoist to do the work for yourself, what do they get out of it? Plus their are insurance issues they would need to think about by letting someone in to work under a hoist that doesn't work there. Bit different if the engine was out and on a stand, but not on whole car up on a a hoist
Seriously dude, rather than just get everyone to list every possible thing it could be, just pick the car up, thank the workshop for their time and "effort" and take your car somewhere else. You will probably find out that it is something very simple and take not much time to fix, or it will be something major and take a bit of work, either way at least you will know what is wrong with it. If the new workshop can't find the problem then you haven't lost anything except maybe a hundred bucks for trailer hire and a bit of your time.
That and your car will look like a fully sik tokyo drifter on a trailer lol
I have already worked on the car while it has been sitting on the dyno. and i have taken my car to another workshop before and they were hopeless. This workshop seams to be good just a really weird and hard to find cause.
Im starting to wonder.... What would have caused the PCV valve to blow out during a dyno run? Because all these problems started to happen after the car popped we found the gromet had split and the PCV valve was sitting out a bit.
Except for you saying it holds boost, I'd say a stuck open wastegate. Is your actuator arm actually working, and it def. holds boost? Then again, a std motor should make more than 48 kw even without FI.
try a different ignighter module then if its a series one.. knew a bloke who had a similar problem, everything seemed good and they couldnt figure out why it was only making 96rwkw on 1 bar and it ended up bein the ignighter module was rooted. just something to think about.
If the dyno is in use, then the proplem should be sourced, we use our dyno as a diagnostic tool, not a tuning tool. unless the dyno is a VAIN then there should be enough equipment to diag the proplem there and then.
Other than that it mean's the equipment isnt being used correctly.
Edited by EFI Performance
Not if that's the timing at idle. It's supposed to be 15BTDC. If it's only 0 (TDC), then the spark is firing 15 degrees too late right across the range. Considering that at full noise, the timing might be supposed to be 10BTDC, then it's actually firing 5ATDC. That's into the power stroke - no wonder it can't make power!
The key on the exhaust cam controls where (at what angular relationship) the CAS mounts. Without the key, the CAS can only be in one position for the engine to run - any other position, and it just won't start.
So if the cam marks are where they should be, The belt hasn't jumped a tooth and if the timing light is showing the right angle then this would rule out the cam? Or would i still need to replace the cam for one with a key and the CAS for one with a key?
Car sitting on a dyno is not the same as car being on a hoist. End of the day it is up to them if they want the potential legal problems it could pose if something went wrong. I'm with Drag and GTST, try the ignitor and the CAT, forget about the cam for now, do the easy quick stuff first!
The loom for the coils plugs into the ignitor. Should be a silver metal thing with finns on it and 4 screw holes. On a 32gtr it sits on top of the valley cover at the back of the engine, dunno bout 33 though, and 34 have the ignitor built into the coils
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
