just some parts that i have left from the wreck
just want to get rid of em
both side mirrors 80
both doors 100
all windows apart from windscreen '
gtr rear spoiler 100
bootlid 60
rear pods 110 not budging on these or else ill keep em
rear bar 60
lhf seat 70
a pillar trims with 3 screw holes for tweeters 50
rhf main power window switch 60
both front clear indicators (clear with abit of orange) 60
lhf headlight with bottom thread stud broken (the one that no ever cbf putting back on) 50
4 kybshocks with king springs front and rear 100
1 rhf type m side skirt 40
front hubs lhf+rhf 150 goood for 5 stud conversion
might have some other stuff which ill put up along the way if i can think of em
cheers
all parts located in melbourne springvale
contact through pm or if u want a quicker reply might as well call or sms 0412-219-552
https://www.sau.com.au/forums/topic/250925-r32-gtst-parts/
im after the demister airvent, the one on the very top of the dash. Let us know if you have one which isnt warped by the sun.
Cheers
lol
sorry keeping these, cause mine have gone and broken into different pieces
https://www.sau.com.au/forums/topic/250925-r32-gtst-parts/#findComment-4345657
its me thats picking them up on monday, at least i hope, i msged ya the other night asking if all the clips are intact and you said you would check monday, let me know mate
Edited by HI2U
https://www.sau.com.au/forums/topic/250925-r32-gtst-parts/#findComment-4347317
possible to get a small cut from the LH rear corner of the boot shut area, not bootlid just the corner, where there is the radius of the boot, rear guard & beaver panel. only need a section about 300mm x 300mm, but you may have to cut the guard or unpick,
is courier pickup an option if i shoot funds over the wire??
let me know cheers nathan
https://www.sau.com.au/forums/topic/250925-r32-gtst-parts/#findComment-4347874
guys if u are interested.
i wanna get rid of the shell, just the shell only so the rear gaurds roof and that are still good just not the front .
if someone wants 100bucks ono pickup
i just want it out my drivway cause its taking up space.
cheers
https://www.sau.com.au/forums/topic/250925-r32-gtst-parts/#findComment-4348196
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
