  • Replies 42
Thanx guys. I found a DR30 skyline with a FJ20DET fitted with a Trust TD07-30G, along with loads of other Trust perforance mods for $13000. Just wondering if this is a good price and what power could i expect roughly.........Cheers
https://www.sau.com.au/forums/topic/25096-trust-td07-30g/#findComment-537485
that would be a pig to drive on the street
https://www.sau.com.au/forums/topic/25096-trust-td07-30g/#findComment-539237
I just saw yesterday a TD07 with the biggest exhaust housing iv'e ever seen. Was bigger than the comp cover. Im thinking nothing but a rotor would be able to spool that thing up.
Iv'e just bought a TD06 20g for mine with the smaller exhaust housing so should be a good thing.
https://www.sau.com.au/forums/topic/25096-trust-td07-30g/#findComment-540609
  • 9 months later...
TD07 refers to the turbine size, and basically means big. The 30G refers to compressor size and basically means big. Whether the 25G wheel on the TD07 is the same as on the T67 im not sure.
If you are having trouble finding info on the TD07, try a search for the T78, basically the same thing, a bit like the TD06-25G and the T67-25G.
https://www.sau.com.au/forums/topic/25096-trust-td07-30g/#findComment-913465
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
    • Ok. What is the go to transmission upgrade that can handle some abuse with around 700nm at the hubs? Must be quiet gears as the car is being street used.
