G'day I have forsale my R32 GT-R
THIS CAR HAS HAD ALOT OF HOURS AND MONEY SPENT ON IT SO PLEASE ONLY POST OR PM ME IF YOU HAVE A GENUINE INTEREST IN THE CAR, NO POINTLESS POSTS OR TIME WASTING.
THANK YOU
Forsale:
1989
BNR32 GTR GODZILLA
4000km on fresh engine and single turbo setup
built by:
PHIL YOUNG AUTOMOTIVE
the GTR made an easy 270kw and 1547nm of torque on 15psi
(this setup has much much more in it, a boost contoller and tune would see it make 350kw)
Details:
5spd manual
Climate control (complete aircon removed)
F1 concept sports wheel
After market race seats
Pioneer cd/mp3 player.
Greddy turbo timer
Drift boost gauge
Drift Oil pressure gauge
Apexi Power FC and Hand controller
700cc Blitz Injectors
BOSCH 023 fuel pump
New water pump
N1 oil pump
Gates racing timing belt
ARP Head studs
ACL Bearings through out
CP Forged 86.5mm Pistons
Complete Head recondition
100% all new gaskets
Metal head gasket
(Every part was either freshened, checked or replaced)
Custom High mount exhaust manifold from Extreme Turbo Manifolds
Garrett 700hp rated To4z Turbo
Turbosmart 50mm External wastegate
Custom dumpipe
Nizmo stainless exhaust
speed flow oil/water lines
HKS mushroom filters
HKS Cooler piping
Greddy catch tank
Greddy turbo intake pipe
Z32 AFM's
EXEDY 450HP clutch
18x9.5" +15 Koya Driftek wheels with great tread
AB Flug style carbonfibre vented bonnet
Garage saurus Front lip spoiler
L.E.D Tail lights
Ganador Style aero mirros
Custom pearl green paint
PICTURES:
(PM ME IF YOU REQUIRE MORE INFO)
PRICE: $24,000 FIRM
More pictures on request.
Edited by BNR 032
https://www.sau.com.au/forums/topic/250974-forsale-r32-gt-r/
    • I don't know if you can disassemble the thing and put it backwards for different ramp rates. They're both "2 ways" or both "1.5 ways" because well, 2 ways and 1.5 ways are the same 'thing' I do not know for sure, but I believe the 38420-RSS15-B5 is the 1 way, and 38420-RSS20-B5 is the two way. In other words, I predict Nissan considers this: to be a 1.5 way. No idea what actually happens when it arrives/you disassemble it. It would be an excellent question to ask Nismo directly! I somehow doubt you will get an answer though, I feel you would be the first person to document what you encounter when you open the box and the internet would be grateful.
    • I'm going to slap an old nismo logo sticker on my spare one and sell it to the land of the free for a thousand bucks
    • lol, probably should have read further!
    • Well - they have arrived.  And they are easy on the eye to put it mildly... These only have three bolts - but for a start there is a key that fits with vacuum like precision..  And as you can see by my ruler, the interface is large..   I listened to a podcast on HP Academy about Dan (KiwiCNC) and I'm more than comfortable he knows what he is doing. R35 Bearing assembly should arrive later today so can mock that up for a look. Can't wait to get these on and get some brake pressure logging too. IMG_3860.MP4
    • I would be very confident that they are the same parts (the 2 different SKUs). It seems very clear that you can drop the cam in the 2-way opening, or in the other opening. If you arrange it in the other opening in the same way that you see any other 1-way diff, ie, with the flat of the cam up against the 1° side of the opening, then it would work as a 1-way. It can only spread the ramps when driving forwards - cannot spread the ramps on overrun. It would then appear obvious that if you put the cam into the opening "backwards", that you would get the angled flats of the cam working onto the "points" of the 1° side of the opening, which would give you ramp spread in both loading directions. I do wonder if the forward direction of the 1.5-way config is equivalent to the forward direction of the 2-way, seeing as the cams are flipped and the angled surfaces on those would need to be the same on each side - AND - clearly when installed in either the 2-way or 1-1ay configuration they are not intended to work exactly the same (the ramp angles on the 2-way are 10° different between forward and backward, and the ramp doesn't exist in the 1-way config). 'twere me, I think I would rather actually have a set of rings that offered the 2-way with two different sets of ramp angles, say the 55/45 of the existing design and maybe a 45/37.5 combo for a less aggressive effect), AND another set of rings with a dedicated 1.5-way opening and a dedicated 1-way opening. The 1.5-way opening would actually have the steeper angle on the overdrive side that causes it to be less pushy than the forward drive angle, like you see in many other diffs. But really - if this Nismo thing is thought out properly and all those surfaces work on each other the way that they need to, who am I to argue?
