  • Replies 67
Posted Images
looks great cara, how did you do it? and what kinda cost was involved?
took the lights out of the cover, cleaned them up really really well with wax and grease remover, did it a few times to make sure there was no crap at all on them
them just got the VHT nightshades and did light coats till i was happy with the darkness i wanted.
i also did my side indicators and front ones too :(
very nice, where can one find this night shade stuff? what is it exactly?
it's a spray on tint ..comes in aerosol can. From what I've read about it before the stuff looks pretty 'matte' black but looking at the photo above it's very shiny so there you go.
Hey Cara what's your suspension height (centre of wheel to wheel arch) front and back ? :(
Hey Cara what's your suspension height (centre of wheel to wheel arch) front and back ? :D
um i got the tape measure out and from the centre of the wheel to the wheel arch is 13.5 on the front and 14 on the back....not sure whether it is in mm or inches dosent say :)
Cara i gotta' admit .. looks nice.
MRXTCZ
cheers dude
you can buy the VHT nightshades from any automotive store :(
um i got the tape measure out and from the centre of the wheel to the wheel arch is 13.5 on the front and 14 on the back....not sure whether it is in mm or inches dosent say :D
extend it to 14 again - is it longer than a foot? or is it around 6"? I doub't you've got wheels on a 34 that on only just bigger than wheels of a mini :) so it'd be inches.
ummm... where's the reflector?
no reflector = defect time.
well spotted......
and those tail lights dont show much actual light when they are on.....i might have to take a pic of mine tonight and see how much light comes thru......but i think its alot more than that :)
tinting lights (both front and rear) has always puzzled me. while it may look cool (to some people) during the day, at night you are reducing your visibility (more chance of someone running up your arse if they are tinted too dark and when the brakes are on only look as bright as normal lights) and with the headlights you are reducing how bright your lights are. i hate driving cars with dull headlights.
now you might think that i should shut my mouth if i have nothing to say, but in fact i was making a point that tinting your lights makes your chances of having an accident higher, and also increases your chance of having your insurance company refuse to pay after said accident because of illegal modifications to lights, and could even possibly have you blamed for the accident if a car runs into the back of you (where as normally it is the person following who is at fault).
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
