Hi guys,
I'm looking at buying a r34 Gtr from Gran turismo autos, i was hopping you could give me your opinion this car from its photos. As i've NEVER owned a car and am a total noob at anything mechanical all the faqs on what to look for in a car are meanless to me.
http://www.drive.com.au/used-cars/NISSAN/G...838730&pt=1
any input will be highly appreciated thanks. :D
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/
Seriously, you DO NOT want a secondhand R34 GTR to be the first car you own when you don't know anything about cars. "Driving a car for 2 hours" doesn't mean crap when there are a lot of things that can go wrong in a likely modified, secondhand turbo theft-magnet. Instead of us holding your hand through every step, the best $1000 you can spend is on a secondhand manual excel. Own it for a year, learn how cars work, then get a R32 GTS-T for a year. Then you'll be ready to fully appreciate and look after a GTR (as well as hopefully manage to secure finance).
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4351811
ummm if you just finished high school that means you have P Plates right?
P plates on a GTR
GTR with P Plates
a bayside blue GTR with P Plates being driven by a noob
can you see where this is going???
firstly cops will rape your ass like theres no tomorrow due to the power to weight thing and on p plates you will stand out like do ballz
your still a kid and would have bought GTR as a first car... you will have to give up more then your lunch money and allowance to keep that thing running
but if you can afford to buy it then i guess you can afford to keep it running...maybe
but for a first car a GTR is not the best car to get if you know nothing about cars
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4351880
GET AN R31
Hold up well in a crash, RWD, cheap in every way, and they can be treated like crap and keep on going :laugh:
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352028
wow..it looks *totally cool* from the ..photos..
gg
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352304
Hey Urgh4, BNR34's are a awesome piece of machinery fast and handling is like ur on rails. If u can get 1 great. But as a fellow Australian and SAU member, becareful this car in the wrong hands can be lethal, get used to how it drives and handles and always respect the car and other road users.
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352339
Hi guys,
any input will be highly appreciated thanks. :laugh:
never owned a car ?
ever driven a turbo car ?
yes i have actually, for about two hours audi a4 1.8t around two years ago.
holiday's great, nothing to do until uni offers
firstly urgh4...I don't know how old you are but I'm guessing your around P-Plater age. With that being said and assumed, you should not buy and own a R34 GT-R for the following reasons (IMO)
1. First you not allowed to drive it whilst on your P's. Putting up P plates on a GT-R, coppers will have a field day with you...and you are on new P plate rules. it's 3 demerit points and a maximum of $1100 fine.
2. You'll pay a hefty sum of money for insurance (let's say your 18 - it would cost 3.5k - 4k to get full comp insurance for a 18-21 year old...you would be a fool get to get thrid party)..in compaision i'm 27 and it would cost me 1.5k for full comp.
3. Service and running costs are higher than any normal car.
4. Driving a A4 1.8t for a couple of hours two years ago doesn't compare to a GT-R.
As what most people have said here...although a GT-R is a awesome car to own and drive....it's not really recommended as a first car. It's very hard now with the new P plate rules as there is many cars you can't drive. Still with something reliable and fairly cheap, get some experience on the road and then once you are off your P's then get the GT-R
https://www.sau.com.au/forums/topic/251326-gta-r34-gtr/#findComment-4352445
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
