just wanna know what the go is with t3/t4 turbos on rb25's
i got a r34 gtt rb25neo
was wondering if anone has put a t3/t4 on a rb25 and what mods they had and wat power they got form it
i have onyl heard one bad thing about the tubro and that is that they may have lag issues.
but if it hauls ass in high then id ont care. :D
so let me know
https://www.sau.com.au/forums/topic/251337-t3t4/
hey check this out, i reckon it suits u well
http://au.youtube.com/watch?v=ag4nLpu1nJ0&...feature=related
that was a joke ^^
HKS gt-rs are good for that power range , other then that mayb highflowd rb25 or rb30 factory turbo or a AVO or IHI turbo, there pretty good too.
Edited by NISMØ
https://www.sau.com.au/forums/topic/251337-t3t4/#findComment-4358643
i jsut want a good turbo that will allow me to go to 250atw with mostly stock parts.
stock turbo only takes 12psi. and i want more!
Please try searching then.
There are pages and pages, threads upon threads about 250rwkw... how to get there, what you need and so on.
A good start is the FI Guide, and the Dyno Result threads, its what they were made for afterall
Thanks
https://www.sau.com.au/forums/topic/251337-t3t4/#findComment-4358672
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
