will follow up...
However there are no correlations to where you are, you can be in Melbourne yet people in WA may get theirs first because when RDA receives the order if they know the WA branch has a stock close by it gets shipped directly from there instead from Melbourne warehouse.
Most likely you were not home when the courier tried to deliver, this had been 99.99% of the cases over the past 3 years
  • Replies 447
I work from home so I'm always here .. besides, even if I had just popped out for a minute (which is unlikely) wouldnt they leave a card ? If you could give them a ring and find out what's happening that'd be great.
.... Keep in mind that general OEM rotors normally have a lifespan of around 30,000 - 40,000km. My front stock V35 rotors were lipped and were already under the minimum thickness when the car landed with 49000km, so I would have estimated the previous owner in Japan didn't replace the rotor at 40000km service which was when it was suppose to be replace. I would expect RDA rotors also have a life expectancy around 30,000-40,000km just like OEM rotors.
I am not trying to be inflammatory, but when I got my R34 it had done 86,000km, and I am quite certain the rotors had never been replaced due to rust and lack of evidence of any mechanical work ever done to/around them. My car has now done 155,000km and they are on their way out but still going. So I have to disagree that OEM rotors are good for 30,000-40,000km.
Either way I am changing to the dimpled/slotted gold passivated rotors, which arrived the other day, and they look bloody awesome in the box!
I haven't fitted them yet as I am waiting for my QFM brake pads and brake rebuild kit to arrive, to do it all at once, along with some braided brake lines and custom caliper paint. :ermm:
as it happens I'll be at a different address from monday for about 10 days .. any chance I can have you give them the new address for delivery? It's also in Sydney.. so if they haven't sent it out yet, it'd be much better if I can get it at the new address.
It is probably already on its way. What I'll do is I'll grab the consignment number and you can ring the courier with that consignment number.
It's a lot easier that way.
Yeah mate I am getting the A1RMS.
Delta what do you think of the HPXs? They recommend I go A1RMS for a mildly hard driven street car (no track time).
my understanding is A1RMS is for track mainly ... ie. they're efficient at high temps. Since I don't do track, I've gone with HPX as they work better at lower temps too ie. street.
only if Falcon's PCD is 5x114.3mm by factory standard, and if Falcon's centre hole diameter is the same or bigger than Skyline. if not then it will be up to the end user to modify their hub to fit.
Reason is they don't do custom made rotors unless you're willing to buy a minimum of 120 pieces (60 pairs) in one order
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
