Up and running again. Ended up having to rebuild my master cylinder as that dumped its seals at the same time... bloody thing is relentless. Bedded new brakes in and all seems good. Thanks again for providing this.
  • Replies 447
nope, sorry. RDA won't do it, unless you're willing to order 1 (forklift) crate consisting of 120 pieces of rotors as a minimum order, they will do it.
maybe you gather 60 owners of those who need blank rotors and share the cost?
Tom, Dav - quotes sent.
Dav0, if your post not enough to send me pm, email me: rsoputro at hotmail dot com
(replace at & dot - you know the drill).
Rianto, would it be safe to sand the midle section of the rotors (not where pads have contact) to get rid off the surface rust and then apply a very thin layer of fish oil to stop it from rusting ?
hm, even a thin layer of oil might splash and leek around - what if it slowly seeps on towards the friction area while the wheel is spinning @ 100km/h?
unless you're preparing for an auto salon or show and shine competition, I wouldn't bother doing it mate...
or if you want you can try finding any hub cover off the internet which is made of coloured anodised aluminium, which could be used to conceal the surface rust on hubs... just be careful that they're not too thick that they reduce the contact amount of your bolt thread.
would you be able to pm me with a quote for slotted rotors front and rear (if you could keep these separate that would be great, cause im not sure if ill replace my rears or just machine them.. all depends on cost) for a R33 GTS T ? Could you also include quotes for the green and red ebc brake pads, again for a R33 GTS T.
Thanks!
Edited by br3ndan
Are the rotors on it came off R32 GTR or are you just using the R32 GTR calipers?
If the rotors are off a R32 GTR, you can measure the front one's diameter across. If it's 297mm (around 30cm) then it's the early models 89-93
If the rotors are 324mm (around 32 1/2 cm) then it's off a 93-94 late V-Spec II model.
Hope that helps...
Hey mate, I am interested in a full set (front and rear) of standard slotted rotors to suit the R33 GTS-t.
Let me know how and when you want payment to be made and I'll make the arrangements.
Thanx champ. :bunny:
roland, quote sent..
Malz34, order added to the list...
RDA group buy 48 order list:
- aleks (payment cleared)
- Malz34 (waiting for payment to clear)
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
