  • Replies 447
Rianto, Just a quick note that i recieved my pads and rotors, thanks for organising another successful group buy!
To those thinking about getting EBC brake pads, I highly recommend the redstuffs and the RDA slotted rotors!
noticed some post missing since the past 2 days...
Update to RDA Group Buy 49 order list: (Closing 7th Aug)
- keii (payment cleared)
- Moodles2 (payment cleared)
- 180 wanabe (payment cleared)
- DriftGTS (payment cleared)
- PhilKenSebben (payment cleared)
- FOOLBOOST (paypal payment cleared)
- br3ndan (waiting for payment to clear)
- BASHO (waiting for payment to clear - R34 GTT clutch)
matt, check your pm. what car is it for?
- br3ndan (payment cleared)
- BASHO (payment cleared - For R34 GTT Clutch kit)
Rianto - When this one is done - can you start a new thread mate?
Its easier for Admin to keep track as there have been some wayward GB's over the past 6 months so we are trying to clean up the section with a bit of policing and more closer/strict rules.
So once the GB is over (as per the start/end date), just start another thread and i will come along and close the previous ones.
Thanks for the GB's, i've left you feedback from my rotor purchase late last year too, i forgot to do it lol :angry:
no problems :devil:
Hi, Can you please let me know how much rotors and red pads are. I have a 2004 V35 350GT. Also are you able to get red calipers?
Delivery would be to Flinders, NSW 2529.
Thanks.
Hi Adrian,
I don't sell calipers, sorry - you could either get a can of heat resistant paint and paint your caliper, or browse the net for a set of red calipers.
Does your 2004 V35 have brembo calipers?
Let me know - cheers.
- shnoog (payment cleared)
- Chi100188 (payment cleared)
Hi Adrian,
Hi, I dont think they are Brembo. They are just a charcoal/silver colour. Cannot see any branding on them.
Hope that helps.
Adrian
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
