ask duncan
hes driven with me
:D
he loved it
... yeah and he's almost finished with the therapy needed as a result :(
I'm thinking about entering the 350 for laughs- should have some decent brakes on it by then.
  • Replies 74
righto( lets lock it in)
money wear your moth is 250 gets you in
i garentee we may not win but we will have the best afterparty
bank details:
peter carruthers
bsb 112-879
acc number 428 965 807
i also garentee that i will spend your money on beer and hookers
pete
0448468884
lol i only have 3 confirmed for " team driving slow for fun"
so if you want in hook it up
anyway if we get to many we make a second team
Edited by fatz
Just read though the regs and have some questions if anyone can help?
- 1.7.4 All drivers must provide evidence of the last 3 motor racing events they have competed in. It will
be the discretion of the organising committee to accept drivers to compete. How do you do this when they're track days?
- Be fitted with a return spring on each throttle in the event of the throttle linkage becoming
detached. What's this???
- Bonnet Catches: Cars must be fitted with at least 2 independent fastening systems, of
adequate strength and limited extensibility, which simultaneously hold the bonnet or panels
closed. Does this mean just 1 additional fastener as the stock bonnet latch is ok?
Cheers
Bobby
Cheers
Bobby
I believe that is correct. The bonnet catch is one. If you have bonnet pins then you are fine (being a 2nd) and not relying on any part of the bonnet catch. I have also seen a nylon rope or strap used as a secondary fastening system from the radiator support panel to underneath the bonnet
Edited by Deano45
At most events now, you actually need another one.
So the normal bonnet release system and then a strap or something.
Its becoming more common now for sprints and stuff, superlap they required it, and some drift days too
Your car has the linkages already bobby :D
I have my team entered now, Team number 1 - well first team entered anyway. I am planning on running my R33 GTS-T as long as everything goes to plan.
I hope you guys and girls put at least one team in, it should be a great event!!
Can you tell me how many cars will be on the track at any one time??
I know under Cams L2S its a maximun of like 8 cars can be on the track at any one time..some of my team mates are bit concerned about the 36 teams all having up to 6 drivers. Thats alot of cars that you need to get through to do there laps.
If there is 20 teams entered there is only 20 cars on track.
In practice you can still only go on the track if you have the sash, one car per team on track at any one time.
Cheers
Adam
Hey Adam,
But does that also mean 36 cars on the track if there are 36 teams?
I'm an unbelievable skillfull driver, but I think when they see fatz on the track the rest of the field will pit and therefor fatz' team will win :)
Seriously though, 36 teams on teh track at once on Wakefield, made up of weekend racers could get a little hairy. What happens if it's wet?
Thats correct, its not that bad really. I have seen 40 Formula Vees on the track there at once. At the Winton 6 Hour last year there were 43 teams, and not one car to car contact. It is not racing for sheep stations, everyone has to watch their mirrors and pass without embarrassment.
Well if its wet that means there is water on the track. :)
Seriously though, if it is raining then it is the same for everyone. Drive responsibly and everything is ok.
I'm an unbelievable skillfull driver, but I think when they see fatz on the track the rest of the field will pit and therefor fatz' team will win ;)
This is exactly my concern as well.
I have seen Wakie with 32 cars on the track at one time and they were racing and it was hairy :(
So what happens in Wakefields eyes if there was an " incident" (rubbing) on the track? Warnings given, sort it out yourselfs?
I just need to reassure my Team mates and hope there still willing to particpate..We are used to the same crowd at our super sprints and everyone knows their boundrarys and there is a level of curtosy...
I guess one way of putting it is" a really big super sprint/track day with just excessive traffic more than what we are used too" ;)
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
