price: 6k
year: 1988
kms:80,000 +
details:
got 1988 nissan cefiro for sale;
Track Only
rb20det
5spd manual
S2 r33 turbo
the 'rare' black interior (not leather)
no pictures, body is stock black with stock wheels.
contact: 0413820421
extra's: can include full uras kit for 500
comes with aftermarket water temp gauge customly installed in the cluster
close up pics are on ignition, on start up, idling for 10 minutes on a 40 degree day.
starts at 100 deg F (which = 40 deg C) goes up by 20 deg C at each main number point
price drop:$5500
has pair of front kei office coilovers installed and a full uras kit included for free
need it gone, no use in my backyard not getting slid
