hey guys...
heh pardon my ignorance...
im drvin a 95 r33 gts...no turbo...:)
just wondering, occasionally, now that im informed by bam n sum otha ppl i can just pop by the plex on a sunday and do runs if i like, is there nething i shd be aware of?
like driving yr car hard prolonged could lead to this that this that...
an occasional whack to 180 on private roads? can spoil e car?
just wondering...if theres nethin i shd be aware of or shd not be doin till i do anythin to the car
thanks
:D
https://www.sau.com.au/forums/topic/25187-drving-hard/
not really unless you're doing circuit work....just watch out for the oil and water temps....
but for the occasional road excercises....there shouldn't be much of a problem...just keep your heater on for a few minutes should do fine...
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-535748
These cars are meant to be driven hard.
To me it's like asking if your BMW M3 can be safely* taken up to 250km/h (*mechanically speaking of course).
Skylines are supremely stable at very high speed. The motors are very responsive with the balance to go to the red constantly.
At speed I fear nothing for the car - just the police :)
T.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-535751
< snip >
driving hard? Talk about reading hard. :( That post was frikkin impossible to read.
But from the little I understood, no there should be no permanent damage as the car was designed to be driven hard. The occasional fang won't do damage unless the car's not been maintained well.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-536707
skylines love bring driven hard...
just keep good fresh fluids (engine, gearbox, diff, brakes, radiators), good plugs etc.
And of course, like fatz said, you need to get sump baffles installed if you want to go over 100km/hr.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537273
good point actually.. like how much punishment can a skyline take day in day out without it actually snapping? Do they start blowing smoke and things? I've never actually seen a skyline that looks "sick" but i guess they aren't at that age where that would become obvious I spose..
not that i really do that to my car, but just curious :P
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537425
the only answer is "depends", but I regularly take my stocker out on the track and use all of its potential when I'm out there.... never had a problem.
Personally, I think with quality fluids, stock boost and mixtures they can take plenty. Its when you move outside the tolerances that the manufacturer expected that you can have problems.
And don't forget a sump baffle.
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-537431
haha just take Gtrken for example .... takes a R32 GTR wth an awfully worn motor .... drags a Mits GTO .... yeah hurts it a little but it keeps solidering on ..... then takes it to JMS drifta-thon .... with clutch n engine worn gives it a good thrashng there .... starts makng weird noses after but it still soliders on
...... theres cars are meant for this over a long period of time .... sure theres going to be slight damage over time but for most part thats why they are called "performance" vehicles!! they are built for speed n an occasional hammerin ..... dont stress .... enjoy!! :D
....... i accept no liability in engine harm that comes from this advice :D
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-538309
A baffled sump will stop the oil from collecting at one side of the sump under hard cornering, which means you won't get oil surge. A baffled sump is desirable if you go circuit racing, but not really necessary for drag racing unless you doing 10sec or better:D
https://www.sau.com.au/forums/topic/25187-drving-hard/#findComment-541196
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
