You can buy the Dump and front pipe as one. If you saw the size of the standard dump i recommend you upgrade. Best mod i did was the Dump+front pipe from just jap and the xforce highflow cat. Makes the car more responsive and come on boost sooner.
did the dump and front pipe fit stright on or did you have to modify it?
im also interested in this, at the moment i have a hks front pipe, hiflow cat and a kakimoto 3inch cat back, with a stock dump.. will it make a big difference to change the dump, i was told not to change it as it wont make a difference.. thanks
I once had just a catback exh. I decided to upgrade the dump/front/cat.
Once i upgraded it all, im not sure whether it was just me or that i lost a little bit of responsiveness HOWEVER the boost hit ALOT harder and the exh had an angrier growl to it(no cats/reso's etc). It pulled ALOT harder throughout the rev range.
Have to be careful tho as you might get boost creep, which an ebc might be needed for then.
front/dump/high flow cat and exhaust, best mod ive done. easy fit. cheap. i already had a cat back system so i saved quite abit of time and money.
my whole exhaust on an r33 gtst series 2 uses the original exhaust mounts.
just jap bell mouth front/dump 3inch, Xforce 3inch highflow cat, fujitsubo 3.5inch cat back....
  • 1 month later...
Sorry for the newbie question. My mate has a N/A R34 (2.5ltr) manual, he wants to get a high flow cat and just a muffler. What size cat should he get? Same diameter as exhaust or bigger? The stock N/A exhaust I think is 2 1/4", not sure. So 2 1/4" or 2 1/2" or 3" cat? The less cell the better yeah? Thanks for any help.
Edited by BaysideBlue
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
