I am about to pull the engine out of my GTR soon to get it rebuilt. For you guys that have been there and done it already, I would like to know what weight rating should I get for each? The engine stand needs to be able to hold the engine with all the running gear on it (turbos, plenum etc). I Guess the crane would need to be able to lift the engine and gearbox.Are there any brands that you recommend, places to buy them from, things to look out for? I am in Sydney.
https://www.sau.com.au/forums/topic/252045-engine-crane-stand/
I did this over the weekend, I used a 2 tonne crane (on the 600kg setting) and a 600kg engine stand.
I bought my gear from Gasweld in Blacktown, from memory it was $340 for the crane and $130 for the stand.
Cheers,
Cheers,
Thanks for that
yeah basically anything will do even though the stands look pretty scarey at times. we use a 2t hoist (on its 500kg setting) and a 500kg stand. it hangs pretty nose heavy but has always been fine
ditto, had mine on a 500kg stand a few times and no issues.
mate of mine has his built jun stroker sitting on a stand, with big sump, front diff, etc... looks very nose heavy, so he has propped a bit of wood under the front just in case..
yeah but no matter how bad they look they have never actually been unstable or fallen, and we have done 6 motors in the last 12 months in the garage.
the only time i've ever dropped a motor off a stand is when I forgot to put the pins in the stand where it attached to the hoist properly = broken balancer and bent crank. ouch.
Do you just use chain to attach the hoist to the engine or use an engine tilter? Where are the lift points on the RB26 engine and how do you attach it?
Thanks
Edited by Deano45
i've done it with just a chain, but a tilter will make it a bit easier.
lift points are front left of the head, and rear right (standing at the front of the car and looking at the engine)
are you removing engine and box, or just engine?
yeah we did it with a chain for the first few years but have a tilter now. it makes things much easier especially with the deep trust sump on the bottom - you need to tilt it back to clear the sway bar then level it back out to get the input shaft in straight.
Just the engine at the moment.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
