evil that is a great install .. congrats .. i think i will do something similar to that ... do u think u can give us the dimensions of that box?? or was it just as easy to draw it up on cardboard?? try it out then build it?? do u find that it fits nicely?? ie how do u mount it to the ground?? stop the box from rattling??
  • Replies 82
nice thread. im planning on building my sub box soon. i want to leave my boot free for future items. so as i dont want rear seats im going to build the box to fit in there. will end up a bit heavy but having two 12's in the back sounds amazing. ill post pics of it once i finish. the problem i have atm is where to place the amps.
your right Nav2k. I guy has a 32 in clarion in a mitsubishi challenger up here in rockhampton. the box take up most of the cargo area. The clarion ute had two in the back of it, but form memory i think they have been taken out and replaced by 6 12 inch subs. The guy up here just fried the 32 inch as well, so i dont want his postage bill when he has to send it back :D
Hippy, I'll measure the box tonight but they will be only basic dimensions. It is quite easy to make a template with cardboard and a good way to start is to pull out the bottom carpet which is perfect to use as a stencil for the bottom of the box. As for holding the box in place, there is nothing holding it. I made it a very tight squeeze (I can't even get it out!) but with a thin metal cable connected to the metal on the side in case it moves.
Originally posted by Craved
was that built straight onto the body of the car with the resin or did you put some plastic/material behind it so it can be removed?
Certainly not permanent! No way I'd damage someones car like that dude. We first mask up the entire boot area before we put the resin and Kevlar it. That way you can pop the entire enclosure out if you need to do something that requires the entire boot. :D
Carbon Kevlar-- expensive!! but good stuff :)
did you use kevlar over carbon to save the amount of layers, hence increase volume? just curious cause stuff like this interests me, wish i thought of it before i started my boot install ;)
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
