Before you decide on a clutch, speak to Keith at KB Clutch Engineering at Penrith on (02) 4732 1692. There are others on this forum who I have also directed his way and they too think he's brilliant.
He knew I was looking for a good launching clutch for the GTR and my concerns with my wanting to ensure the clutch was the weakest link in my drive train. He agreed and basically told me that the only thing a twin/triple clutch will give me over one he would custom build for me was 'bragging rights at the pub'. He then proceeded to build me a spectacular launching (brass button) clutch for under $500... and those who have seen her launch at the hillclimb will know what I'm talking about. This is at the same time that some local businesses were trying to talk me into a $2300 clutch!!!
He will build it according to the way you want to drive it and won't rip you off. He also rang us while we were putting it in and gave us some tips. I'm pretty sure that he also does the work there if you don't want to put it in yourself.
The Evo people also use Keith for their race clutches... just ask Martin Vitaris.
If nothing else, just talk to Keith before you decide. He's a very genuine person to deal with.
Keith may do a good clutch at a great price, but if you ever try the difference between Michelle's clutch and my one, mine is so much lighter and easier to use. Saying that it was built for launches at 350rwkw and it cost $1300, a big difference in price. Your choice.
Trojan did my clutch replacement but I got the clutch myself.
My twin plate is pretty light and easy to use... If you ever get sick of the jittery noise they make just install big cams to drown them out :)
I have an Ogura, was hard to find one in stock in Aus but was lucky to find an almost brand new one at a Jap wrecking yard.
Like I said though, Keith custom built this one to my launch specs, not street use. That's what I wanted at that time, but if I had said make it soft and easy for the street, he would have. He really knows his stuff. So please don't think he only builds clutches for launching, he quizzed me for half an hour before he made his final recommendation, now that stock GTR is doing split times similar to my Formula Holden which can get from 0 to 100 in 2.7 seconds and only weights 600kg.
Autotech just replaced my clutch and I'm really happy with it. That's the second one Ed has put in for me, first one was before he moved from Integra (way back when I could have a little weak one!!)
If you dont mind me asking GTRKat, how much did they charge you for replacing your clutch?
It was no extra charge as my engine was out and they had to put a clutch in anyway :P
Give the boys a call and I'm sure they'd be able to tell you easily enough.
I gave autotech a call and I got quoted $780 + gearbox oil. Is this what everyone else is paying around?
that doesn't sound too bad even without a clutch... its a shit of a job, very hard to get to. Mark invented new swear words while he was trying to get into some tight places with my car.
I should have said mine was also designed for the same specifications except for a car making a lot more power, and being Jim berry it was a lot longer then 30 mins on the phone :-). Trojan commented on it being a surprising good clutch feel.
As for the clutch replacement if that cost is not including a clutch, call Trojan. Mine was a bit less then that. More like $550 from memory????
I went past Torjan and they were closed! Must be on holidays eh? Does anyone know when they are getting back?
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
