  • Replies 93
Posted Images
Thanks, Snowman after I just spent time to do this one... ;)
My new wallpaper.. if the grey background pic is crap,
use the other one with any colour background as its transparent.
why cant I see these??
The transparent one should look like this, only full screen for 1024...
Haha - less than 2 weeks. My 1st rally is on Jan 31st in Tassie. The car is being entered as a 2005 Nismo GT-R Z Tune (hence why I've done the kit).
Might be a stupid question, but can I ask why?
Good luck this weekend also.
Well actually the main reason was costs.
Under Tarmac Rally regs the cars have to run to factory specs with minimal modifications allowed under strict guidelines. And given my car has been a modified club track car for the last few years it was no longer anywhere near standard R34 GTR V Spec N1 regs and to bring the car back to those specs was going to cost a mint.
However the car was already very close to the Z Tune specs. So the $$$ outlay for me to enter the car as a Z Tune was much lower and meant I could actually afford to do it. The thing is until 2009 the Z Tune had been banned from being an eligable car for Tarmac Rallies (along with a bunch of other cars including the 400R for example - and still is banned for CAMS based rallies) so it has only become an option for me now.
Plus - it looks so cool! :(
Why is that? Unfair advantage?
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
