hey looking online for some injectors this arvo for my 32 GT-R build and came across a set of Denso 1200cc/min 11mm Fuel Injectors (Low Impedance) for $990 a set ($165 each) brand new.
just want to know if any body has used them or would recommend them??
cheers Aaron
https://www.sau.com.au/forums/topic/252387-denso-1200cc-injector-any-good/
no, would like to though!!!
it's just that these were cheaper than the 600cc and 700cc ones and the reason given to me when i asked them y that was,
was "more we sell the better price we get and therefore the better the price we can offer" , so i spose they sold more of these....
so it would be cheaper to get thses ones, and you never know one day i might thave 1000+hp :)
Well considering im selling Nismo 600cc delivered for 1k even...
I dunno where you've been looking to suggest they are more expensive.
Sliding performance sell them for a little more than i am (i think its $1050, so $60 over the price of 1200cc), so again, i think you're getting prices from the wrong places if you cant find a set of 600's for less than $1100 delivered
i never said that i can't find 600cc or 700cc cheaper....... :)
what happened was that the place i saw these had DENSO 600cc & 700cc injectors aswell, it was just that the 1200cc were cheaper than them...
i was under the impression that 1200cc injectors would have been more expensive than 600cc or 700cc ones, that was all...
i was just wanting to know if any one uses DENSO injectors and if they were any good, so i could decied which brand and what size to buy..
Denso is one of the leading injector manufacturers. That is all.
  • 1 month later...
