after reading about threads on stock airbox and these filters I'd like to get one.
Whats a good price?
Wheres the best place to get one (Brisbane)
Oh I just went to the k&n site but am unsure which model to get as they dont have skyline under their nissan section.
..although i have heard something about them being the same used in the VL commondore???
https://www.sau.com.au/forums/topic/25240-kn-panel-filter/
WRX is the same size as well I think, I paid $109 on sale in Melbourne for one, normally $130 or something like that. In the stock airbox there is some noise reducing padding stuff on the underside of the top, if you rip it out you can a more noticeable blow off valve sound. Very rice.
https://www.sau.com.au/forums/topic/25240-kn-panel-filter/#findComment-538230
  • 5 weeks later...
Thanks for the tip MrZac. Just removed the padding so hopefully on the way home from work tonight I hear a difference.
Does anyone know how to clean these K&N filters? Mines been in for a few months and looks a little dirty.
https://www.sau.com.au/forums/topic/25240-kn-panel-filter/#findComment-577501
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
