I have installed a new surge tank, 6AN, 10AN lines and external pump and a Tomei fuel rail in the car and have a really bad smell of gas. I do not have the lid (cover) bolted down because the way I am running my lines but know of someone that has his cover off as well and he gets a very faint smell. I am also missing my rear speakers so the fumes penetrate the inside of the car.
I can let the car run for twenty minutes and use lintless blue towels and wipe all the fittings and where it comes out and back into the tank and surge tank and I never find the towels get wet. I have posted a couple of pics to show how I did it. Can pressure be pushing past the black ring the holds the intank pump in place? Is the gas tank sealed on the bottom of the car so when the top cover is on it is completely sealed? The original breather is still plugged in.
Has anyone else gone through this? I am scared to start my car. I have to open it up for a few minutes to clear the fumes out.
Edited by richsrq
mate im going through the same sort of thing ..i would try and put the filler from the standed tank to the bottom of the surge tank ,then have the return form engine above that ,and then have the return to standed tank out ofthe top if that make sense....are you using speedflow fittings ?
i have gone right through my car and put sealent stuff on all fitting ,it has made it better .
just my thoughts cheers
I will look into relocating the line you were talking about. I am using AN fittings. I used a liquid teflon on all the fittings going into the surge tank (they leaked before I did that and they were a 3/8 NPT) and it stays dry. I did not put sealant on the AN side of the fittings though.
any fuel system in the boot is going to stink out the car. nothing you can do about it
change the lines to teflon or hard metal bent pipe and your smells will disappear.
its the rubber line 'sweating' fuel. Funny thing is when we race the car with leaded fuel...no smell...its only unleaded that sweats.
Edited by DiRTgarage
You can buy lines/hose that do not sweat, they are not cheap however :P
I get a nice smell everytime i get in, honestly you do get used to it and 30 seconds of driving with the windows down gets rid of it.
You notice it more in the heat, in winter mines not bad... one day ill get the expensive hose!
Teflon hose is not as expensive as you may think, the expensive part is changing all the hose ends as they are completely different. We do have SAU pricing on all Earls products though.
Here is a picture of what we did to help combat the dreaded fuel smell. I'm also happy to report that the fuel smell from all the teflon lines is only noticeable once in a blue moon, although I'm building an enclosure for the surge tank which should help even more.
I would of thought that the line I was using and the fittings were the best to get. The amount of money I have spent to make this was stupid. I hate learning the hard way. Is the teflon hose a rubber hose with black teflon on the outside?
The line and fittings you used are excellent for reliability and burst pressure, they just aren't the best for keeping the fuel smell in.
Teflon hose is a semi-solid inner teflon core with a braided stell outer, it can also be in a nylon sheath.
no teflon hose is the same as the hose you have but inside instead of having black rubber its clear/white plastic (teflon) and needs different style fittings to fit it.
What kind of fittings work with the teflon hose? Are they the barbed type that you need to soak the ends of the hose in boiling water to expand it so to get the hose on?
Thank you all for your input.
They are the same style screw on AN fittings you have used before, however they use an olive to give a good seal.
This picture shows teflon braid and fittings, the easiest way to determine if the line is teflon is that the hose end will have a slight curl up where it meets the hose.
just curious the guys using teflon how abouts do you go connecting it to the stock fuel pump cradle? just a normal hose clamp over the hose?
We used an EFI hose clamp, not just a normal hose clamp. Which was the same way we attached the hose to the hard fuel lines running under the car.
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
