its pixel art, there is a thread in the computer art section and you can go to
www.pixelcarart.com
or
www.pixelcars.com
usually theyre made using photoshop or ms paint
People use different programs to edit
i use Paint, some use photoshop and illustrator i think
refer to the links and thread above, and try to attempt it yourself. Ask for help if there's anything you don't understand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
