after seeing this im gonna get my ppg straight cut a servive i think...
When ppl get there dogbox serviced what do they do though?
Not talking about just the change of oil but is there anything they can do to give it longer life?
yes all true, but. unforntunatly with a dog box you do need to crack test the parts. its just a fact of life. you smash something with a hammer for a year or soo it will crack. just when is the gamble.
Dave what sort of km's has your box done since you built it? Do you use the clutch for upshifting?
I had my PPG straight cut dog pulled down and inspected after about 6000kms of use Street (85%) Hard driving 15%, it had a very small amounts of wear on the dogs maybe due to the fact i always use the clutch for shifting i find it way to rough otherwise..
well i bought it secondhand. so id say its got a few.
that and me having to trial and error the best way of "street" driving it.. my guess is at least new dogs for 2nd and 3rd. (so all the dogs lol..) and depending how worn the gears are, them to. (2nd,3rd)
i use the clutch. just shifting fast and firm with a pause going up gears and rev matching down. (down is way more easier than going up....)
waht sort of shifter is recomended. a quick shifter or stock???? i was thinking of making a super quick shifter but im to scared of missing a gear.
i almost got reverse on the freeway once going from 5th to 4th :s (full monty box)
I still run the standard shifter but have been wondering whether or not to upgrade to a short/quick shifter for quite awhile.
The ultimate shifter would be the stillway 0-400 with the lockout but its no good for circuit..
These boxes can be fatal if you mess up, 5th to reverse would have been real nasty goodbye engine clutch gearbox and possibly your feet/legs.
2nd to 1st on the upshift to 3rd is what worries me its easily done alot of people have found out the hard way myself included...
Driving a GTR with a Dog box is no joke it makes you appreciate a driver like Mark Berry that goes lap after lap without a problem...
People need to take this into account before installing a dog box one mistake and you can turn 20 grand+ into scrap...
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
