Hey Everyone!
I just bought a Skyline R34 25GT, non turbo unfortunately...
Anyway, starting to think about giving the car a bit of a facelift, but I'm not really too sure where to start.
I'm thinking of doing the interior first, any ideas on easy stuff to DIY? i'm working on a bit of a tight budget.
https://www.sau.com.au/forums/topic/253170-just-starting-out/
forged LS1 TT conversion, brembo's, full carbon bonnet, boot, roof, front bar and skirts, motec ecu and dash, seam weld chassis, full roll cage, buckets....
oh... budget....
err... gearknob?
That's pretty nice man :P. Good to see it's manual - I got a 4 door sedan (taxi), which I wanna convert to manual some day, maybe even to RB25DE+T too.
A Pod filter will make a difference so that's a good place to start...other mods like redoing the interior??? How brave do you feel??? I'd personally like the colour of my centre console changed to something darker...
Dunno man, just have a good look through the car at things you'd like to change.
Honestly a Pod filter wont make much of a noticeable difference except for the noise factor, but steering away from the debate on that (there are a fair few threads around discussing the effectiveness of a pod) it seems like you have the factory 4dr rims if im not mistaken?
Maybe get yourself one of 666DAN's LED kits for the dash, assuming your still sticking to cosmetic mods for the moment, i changed mine to blue last night, looks really good.
nice car,
maybe some throw over seat covers if you're on that tight of a budget? When I had my r34 I just got some plain black throw-overs with 'skyline' embroidered on the top section
you can kind of make them out in this pic
Edited by Yo-Yo
mm yeah i was thinkin of adding the stock gt-r rims... dont really wanna attract too much attention from the cops adding flashy aftermarkets
the post on repainting the centre panels were a great help, thanks for the reference RusH, gonna go grab the spray paints and sandpaper very soon.
also at the moment buying some gear knobs/pedals/e brake handles
by the way, i found a really good wrapping kit for the interior, i wont be getting it for awhile since it costs around 600 to make a set. its on ebay if you just search r34 leather, you will notice it quite easily, hope thats of some help to everybody, but im sure u all already know about it, but just in case :P
anyway, thank you all so much for your help will be getin to work on the car ASAP :D and will post up pics of the results
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
