so i go looking at the timeslips on SAU..... WTF...... not one stagea in top 20....... theres even a frickin magna there running 14.8 ! c'mon guys surely there's a stagea out there quicker than the magna !?
thats it.
I will be going to willowbank soon. test n tune probably 4th feb now, and should come back with a magna beating time.... if you stagea owners have any pride you will do the same :) <---- thats a joke, but i mean it :laugh:
Jez
https://www.sau.com.au/forums/topic/253430-timeslips/
tomei's do a 2.8L stroker for the 25 i beleive... i'm not 100% sure, but 26 crank/rods/pistons fit in a 25 block, so i imagine they would all work.. however you are much better off starting with a 26 (as most people do, thus the lack of stroked 25's)
and brad's is stock... JUN 2.7L stroker with T04Z from factory :(
https://www.sau.com.au/forums/topic/253430-timeslips/#findComment-4380368
yer as mentioned its a rb26 with 2.7L jun kit and hks t04z, 18psi is very low boost for the setup, the motor is in another car now and will be tested to its full potential very soon if i get off my arse and finish it :)
The new setup is rather disapointing for me (slow) but its all legal and engineer approval is 99% sorted and it will become my daily driver. Its now got a new engine combo, rb26 head, rb30 bottom end, gt3076r, stock gtr 5 speed, etc, im thinking a gt35 is on the cards because it needs more power to push the heavy thing along.
https://www.sau.com.au/forums/topic/253430-timeslips/#findComment-4382399
yer as mentioned its a rb26 with 2.7L jun kit and hks t04z, 18psi is very low boost for the setup, the motor is in another car now and will be tested to its full potential very soon if i get off my arse and finish it :P
That's exactly my dilemma, although I'll be staying with2.6l capacity: GT35 seems to be the way to go - my little N1s are struggling to really get the car moving like I want it to...
https://www.sau.com.au/forums/topic/253430-timeslips/#findComment-4382588
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
