I am pretty sure nothing needs to be changed, you may need lower mounts as the rb30 bottom i think is 38mm bigger. I am also sure rb25 pistons will fit but may not be the best option you should go with, forged pistons will definently be the best option.
Aftermarket ECU is a must have and with a dyno tune you should be set mate.
this is exactly what im going to be doing, but i will be smacking GT35R on the side of mine :(
The neo head has slightly smaller combustion chambers than the normal rb25/26 head, its somewhere around the 60cc per pot compared to 64ish cc in the normal head. This makes quite a bit of difference to the CR.
With the na rb30 pistons, a deck block, thin hg and the neo head, that would have to net around the 10:1 if not higher. I think the na rb25 pistons might be a tad too much but just grab one of the online CR calculators and start plugging in numbers and you'll see what you'll need. I havent really looked that much into the na side of things since will be going the turbo route, but with mine acl rb30et pistons, neo head, decked block and a 1mm hg will get around the 8.5-9.0 CR mark. Obviously with the na route you would want much more than that
if you are using the neo head and want a high compression turbo motor (RB30DET), grab the flat top CP pistons that spool sell in his kit for the normal rb25/30. Depending how you set up the motor, you'll get anywhere from 9.0 to 10:1 CR, i doubt you'll want more than that
I want mine around the 8.8 mark, still responsive but will still like some boost :)
Im aiming to run everything as standard just with the 30 bottom end and 25 pistons switched. Then a safc will prob do for the extra fuel. Wat machining is required? and do i need a better oil pump than the vL one?
You will need water pump collar and to relocate a pulley.
Google "RB30DET" and .pdf. there is an awsome file out there.
i'm going to take a stab in the dark and assume you meant oil pump collar instead, but thats only if he uses a widenose gtr pump :D
Edited by R34GTFOUR
if its going to be a daily the rb25 pump will do the trick, you wont need the crank collar sine the rb25 runs a narrow nose crank like the rb30
If you are going to spend abit of $$ on the conversion and track it abit, an upgraded oil pump is good insurance
  • 3 years later...
before this goes any further, and before a motor blows up
a neo head has a smaller chamber, ive measured them between 52 & 55ccs
in the tech section there is a simple maths formular i wrote up to work out your actual compression ratio, guessing = problem waiting to happen
flat tops with neo head estimated around 9:1 static
  • 1 month later...
So as OP posted what kind of compression it will reach Neo head and 30 block, couldn't find the answer and really bad in calculating compression I am looking around 11 for my NA setup
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
