Mate, I'm runnin in my R32 Gtst 14psi, dyno'd at 165.6rwkw/457Nm @ 6500rpm tuned on a 28deg day by Dr Drift and only managed a 14.452 at 98.7mph.
I have a full 3" turbo back, hi flow cat, intercooler, pod, bigger fuel pump & boost controller for the life of me couldn't break the 100mph mark no matter how many times I tried(did 15 runs)
My best re-action time was .440.
There's a big difference of what a 20yr old car can do compared to a fresh outa the factory car sprouting figures on paper is meant to do.
Mine before remapping was puttin out 116rwkw with all the mods I have listed and was running lean as up top before remap.
The only way you will know is to get it on the strip & see for yourself- if your up in Qld your welcome to come to our next Drag day & see how you go-we would love to see you there-Qld Events team out :D
perth but thanks for the friendly invite :P gunna try get a helmet off a mate and go to kwinana this coming wednesday. will post the results.
  • Replies 63
Posted Images
turbo back exhaust
Profec B 1bar (a little more boost than is good for the turbo just for the drags)
Bosch 044 in tank fuel pump
remapped ecu
9 puck clutch
Cold air partitioned air filter (metal pipe turbo intake)
Full suspension kit setup with pineapples, revalved Tien's and camber /castor setup for traction
Decent width 245 rear tyres with some air let out.
turbo back exhaust
remapped ecu
9 puck clutch
nice, hmmm well im on my way to that :)
already got 3" metal intake(best induction noise ever :)), full zorst, brass button clutch. needa partition my intake though for cold air. gunna get injectors and pump soon with an ECU remap. Got pineapples set up for rear squat atm and i have ALL of the front and rear bushes, adjustable where available sitting in my room waiting for swaybars to arrive before i install them. tyres are 255's but shitty ones, i dont think ill put more than 13 psi through the turbs though. wait till i get a 25 turbo.
I been told 25 PSI in the tyres while I'm at drags. That about right ?
cbf drag radials. I'm either gunna get some adrenalins or potenzas soon though. Should be better than the cheap crap on there now
trial and error with the tyre pressure.
too low and you will have less contact patch on street tyres and potentially lower the grip levels.
start with 30psi hot pressure and drop a few psi at a time if you think this is a problem.
drop it down to 16ish psi
the rims wont spin inside the tyres or any of that rubbish
If you're running 40psi in your tyres with the 1/4mile runs, thats half your problem. Also with the launch, dont dump the clutch, hold the revs up and "feather" it out and jump on the throttle at the same time. You should get 2.0 or even 1.9 with a good launch
  • 3 months later...
For anyone who is interested i got down to the drags the other day and this is the results, if you havnt read whole thread i was testing against an iPhone app.
also again, car is stock motor/turb o, just a pod, 3inc turbo back with stock cat and a FMIC.
first test run:
Actual data from motorplex:
ET: 14.73 @ 158.98kmph
60': 2.54
330': 6.46
660':9.68
1000':12.43
iPhone app data:
ET: 14.75 @ 157.9kmph
60': 2.36
330': 6.34
660':9.60
1000': 12.4
second test run:
ET: 14.89 @ 159.32kmph
60': 2.71
330': 6.65
660': 9.83
1000':12.59
iPhone app data:
ET: 15.28 @ 152.9kmph
60': 2.72
330': 6.79
660': 10.06
1000': 12.91
my best run for the night was a 14.45 @99.33 mph, wasnt a good launch or change into 4th either, so i know it can go faster
I went to the drags in my 32 for the first time and ran a best time of 13.761.
Trap speed was 104 mph.
Running an RB20 dynoed at 197kw atw, on 255 adrenalins at the back.
Had real problems keeping traction to the ground, so I reckon my time can definately be improved on.
Nice, close to the magical 100mph.
You RB20 boys make me sad ;) stupid heavy ass 34s :P
Def will get a high 13 with a good launch.
Its interesting your MPH tho. I ran 99mph with a cat back and around 10ish psi of boost (extra spring on wastegate, so it didnt hold anything like an EBC) - and on the dyno it made just over 160rwkw.
So with my extra weight, 19s etc, hopefully I am maybe 170ish rwkw in fact, to be pulling the same mph. ahhhh who knows.
Either way looks like the Iphon app goes alright sometimes, and not so good others :)
Edited by Granthem
The only way you will know is to get it on the strip & see for yourself- if your up in Qld your welcome to come to our next Drag day & see how you go-we would love to see you there-Qld Events team out :devil:
I ran mine at the same event with pretty much the same mods but with a highflow turbo making 175rwkw untuned ran a 14.32 and a best of 100.90mph.
Now with the car off getting a few upgrades along with a Haltech installed and tuned I'm hoping to get close to the 110mph mark.
what do you guys think my 32 gtst will run with about 210 too 220rwkW?
could have up to 250 when done but that is the most conservative figure i have been quoted
upgrades are:
-rebuilt engine (metal head gasket, rings, ACL bearings, completely recoed head)
-GTR injectors (fresh cleaned and serviced)
-OS Giken Cam Gear on zorst side
-Gates Triple Strength T/belt
-FMIC
-Walbro 550hp fuel pump
-sard fuel reg
-full zorst, no cat (shhhhhhh)
-pod
-KKR430 turbo
-Microtech LT16S ECU tuned by Tony Rigoli Performance
phew lol
so i wanted high 12s...think thats possible on coilovers and second hand 235s?
also what power figures sound more on key?
gotta beat my mates 6litre HSV Maloo lol
upgrades are:
-FMIC
-sard fuel reg
-pod
-KKR430 turbo
phew lol
All the guessing in the world won't make any difference in your life unless you actually do it for real. What is happening with you guys these days ? What's next, asking if you could sprint 100mtrs in 7sec if you were wearing so and so shoes and had your hair parted in the middle for less wind resistance ? Perhaps if I tell my phone I weigh 100kilos and can leg press 600lbs for 12 reps @ 8% body fat I could get that down to 3 seconds.
These guessing gadgets are useless. Get out there and as Nike would say, "just do it".
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
