whys that???
Because if you running a twin scroll turbo (and I'm not sure whether the 4088 is) you will have better pulse energing by keeping the ex gasses separate up to the ex wheel by having twin gates.
Otherwise a single gate will allow pulse energy to "crossover" from one collector to the other prior to the ex wheel. If you look at the full-race twin scroll mani's they all have twin gates for this reason. The original twin scroll sr mani's were previously twin gate tubes merging to a single gate but are now also available in twin gate.
Edited by juggernaut1
  • Replies 52
ok, i understand fully, yeah the 4088r is a twin scroll housing...
thanks for that..
Nice manifolds. Theres some really nice RB gear out of the states.
6Boost ones are great when you finally get one and once its made to fit the engine.
I wish I could afford an R31house Takoashi Project manifold and T04E Pro-T for my 31...But at $4,500+ for the bare manifold...nah.
DR30 FJ20ET kit..
I heard the tuned length manifolds make no differrence due to all the bends they cause a restriction which makes them as good as any other and what makes those manifolds worth so much why not just get a six boost?
because they are works of art.
oh, the restriction is the turbine wheel :)
it would be very expencive to get each runner bent up perfectly to shape with no welding except for the turbo and head flange.
the dude that has the gibson r31 has priced up a replacment.... (same style as the fj one above) he told me $10,000 and had to be hydroformed.
the full race ones are expencive because of the materials they use and that the are welded by a robot. (very pricy tooling)
can i join the waste gate flanges 2gether and run my 60mm gate on my full race manifold ???
i understand the pulse energy yous were talkin about bieng greater by using the 2, would it make such a difference if i ran the single ????
i understand the theory with it, makes sense, but personally ive never had a problem at all controlling boost with my single 45mm trust gate on an ETM split pulse mani runnin split t04z. thats running 15psi right up to 30psi :-s
This is a response I received from Geoff at Full-Race in respect to my query on single gate vs twin gate during the development of the dual gate T4 twin scroll manifold for sr20's when I ordered my sr twin gate twin scroll manifold a little while back.
Ian --
glad you like it. We have done back to back testing of the dual gate vs single gate, and the difference is significant. In fact we have to add about 18-25% more fuel from 3000-4200 rpm due to how much more air is being moved since the turbo spools up so soon. i can pull the results off the dyno computer next week (ill be on the dyno then)
The comparison results were done on a T4 3582R and a T4 4088R.
The use of twin gates on T/S manifolds is not about boost control - I've no doubt a decent gate will ensure that...........as can be seen from the above response its about improving pulse energy to drive the ex wheel which in turn spools up the turbo sooner. A single gate will 'leak' between the collectors as you are unable to create a perfect seal between the gate tubes.
Cheers,
Yes if you quiz Geoff he'd tell you it's all about keeping the flow rate high and the pressure low . You want the pressure rise and fall ("pulse") to be sharp and quick and to be as good as it can be you need total isolation of the front and rear three cylinders (on an inline 6) all the way to the turbine nossles .
To have one ext gate means it has to be able to vent both sides and that means having a divider at the gates collector/mount . The divider can't touch the gates valve because it won't then seat and seal . The small gap necessary does allow some leakage and this affects the manifold pressures being high or low when they need to be , not as sharp or quick in the changover so some of the positive pulse energy is lost .
Still better than a single scroll housing but not the ultimate .
A .
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
