Hi all,
I have been quite active in trying to source some Series 2 Front Pads other than from Nissan (Front pads - Hitachi HP63H FF
about $220/pair), locally in Australia and I think I may have found an alternative.
OPTION 1
Brand: Ausbrake (Australian Brake Company) http://www.ausbrake.com.au/
Application: Stagea Series 2 Front
Model Number: DB7648A
Cost: $85/axle set inc GST + Delivery
Available from all approved dealers Australia Wide and maybe from others as well.
See here for locations http://www.ausbrake.com.au/Aus%20Brake%20Main.htm
Ausbrake is the Victorian, South Australian and Tasmania distributor for QFM brake pads so the two companies I believe are closely affiliated.
I got mine over the counter from Brakewest- Sunshine, VIC. http://www.brakewest.com.au/
I personally printed out the brake pad template from the Japanese application chart from Fujibrake and got Brakewest to match them up against the above DB7648A pad.
http://www.fujibrake.co.jp/pads/fblpad_e.php?fblno=AFP385S
Photos to follow.
OPTION 2
If you are after another alternative here it is from Hawk (US Pad Manufacturer)
Usually instock from V-Sport - Sydney www.vsport.com.au
Brand: Hawk HPS Compound
Model Number: Model HB387
Lining Number: 7766
FMSI Number: D888
Cost: $161 + $12 Delivery
I am sure that Bendix and other local manufacturers will start to manufacture an alternative as well given time and increased popularity of the cars in Australia.
REAR PADS
The rear Series 2 pads are Bendix generic number 1399 (US spec J30 Infinity 1993-1997)
http://www.bendix.com.au/ReverseLookup.aspx?SetRefNo=db1399
https://www.sau.com.au/forums/topic/253995-series-2-stagea-front-brake-pads/
moderators- add to stagea brakes thread sticky methinks??????
Yes good idea.
I have already posted a cross reference in the 'Stagea Brakes' thread sticky to this post.
Here are the photos attached.
Yes good idea.
Here is the cross reference link to the 'Stagea brakes' thread sticky.
http://www.skylinesaustralia.com/forums/St...00#entry4387782
Hi all,
OPTION 1
Photos to follow.
OPTION 2
Lining Number: 7766
FMSI Number: D888
REAR PADS
Very nice!!
I can see it's in an Aus Brake Box, that doesn't tell me who makes it. Aus Brake are a distributor as you've said for QFM, who manufacture pads, to the best of my knowledge Aus Brake don't manufacture pads. I'm just curious as to what they're putting in their boxes cause that's definitely not a QFM pad.
Link to THIS thread added to the Stagea Brakes stickied thread, so we can all cross-reference back to here...
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
