Hi all,
I have been quite active in trying to source some Series 2 Front Pads other than from Nissan (Front pads - Hitachi HP63H FF
about $220/pair), locally in Australia and I think I may have found an alternative.
OPTION 1
Brand: Ausbrake (Australian Brake Company) http://www.ausbrake.com.au/
Application: Stagea Series 2 Front
Model Number: DB7648A
Cost: $85/axle set inc GST + Delivery
Available from all approved dealers Australia Wide and maybe from others as well.
See here for locations http://www.ausbrake.com.au/Aus%20Brake%20Main.htm
Ausbrake is the Victorian, South Australian and Tasmania distributor for QFM brake pads so the two companies I believe are closely affiliated.
I got mine over the counter from Brakewest- Sunshine, VIC. http://www.brakewest.com.au/
I personally printed out the brake pad template from the Japanese application chart from Fujibrake and got Brakewest to match them up against the above DB7648A pad.
http://www.fujibrake.co.jp/pads/fblpad_e.php?fblno=AFP385S
Photos to follow.
OPTION 2
If you are after another alternative here it is from Hawk (US Pad Manufacturer)
Usually instock from V-Sport - Sydney www.vsport.com.au
Brand: Hawk HPS Compound
Model Number: Model HB387
Lining Number: 7766
FMSI Number: D888
Cost: $161 + $12 Delivery
I am sure that Bendix and other local manufacturers will start to manufacture an alternative as well given time and increased popularity of the cars in Australia.
REAR PADS
The rear Series 2 pads are Bendix generic number 1399 (US spec J30 Infinity 1993-1997)
http://www.bendix.com.au/ReverseLookup.aspx?SetRefNo=db1399
https://www.sau.com.au/forums/topic/253995-series-2-stagea-front-brake-pads/
moderators- add to stagea brakes thread sticky methinks??????
Yes good idea.
I have already posted a cross reference in the 'Stagea Brakes' thread sticky to this post.
Here are the photos attached.
Yes good idea.
Here is the cross reference link to the 'Stagea brakes' thread sticky.
http://www.skylinesaustralia.com/forums/St...00#entry4387782
Hi all,
OPTION 1
Photos to follow.
OPTION 2
Lining Number: 7766
FMSI Number: D888
REAR PADS
Very nice!!
I can see it's in an Aus Brake Box, that doesn't tell me who makes it. Aus Brake are a distributor as you've said for QFM, who manufacture pads, to the best of my knowledge Aus Brake don't manufacture pads. I'm just curious as to what they're putting in their boxes cause that's definitely not a QFM pad.
Link to THIS thread added to the Stagea Brakes stickied thread, so we can all cross-reference back to here...
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
