  • Replies 44
nope... its like us... as soon as we get em done we make em loud again :(
mine is JASMA approved cause it has an extra muffler... which im going to remove this weekend to see what she really sounds like :)
yeah mine is jasma complied
i removed that second muffler or resonator
it cost me 50 bucks to replace it with straight thru pipe
but man it sounds sooo much better now
idle is a lil louder but still quiet
but when you start revving it, man its sounds like a whole new exhaust. starting to get popping as well and more of a evident droning sound as opposed to before.
btw is it illegal to chop off the resonator thingy?
btw is there a difference between dump pipe and front pipe
or are they exactly the same thing?
cos i asked the guy that chopped off my resonator how much for a dump pipe
he said 220 fitted
im was like wtf that seems incredibly cheap
they are different... dump is the part off the turbo... front pipe is the pipe from the cat to the dump... well im pretty sure thats what they are... i brought a dump and front pipe in one for 200 from Steve (phat32) keep forgetting to call ICE to get it installed... they said it would only be about 80 to install.
Depends, some "dump" pipes are like one-piece from the turbo to the cat, others are split into two pieces where one is the "dump pipe" and the rest is the "front pipe".
Mine is like 2 pieces. Think it helps when you get a bigger turbo as rather than replacing the whole thing, you just replace the dump bit so it fits the new larger turbo.
ok so we took it to daalder on friday...
"no way"
was the response lol
in other words he said it was a waste of time welding a resonator in cause it wont make it the legal limit either rofl.
its cause its a fat straight pipe with a near hollow cannon on the end... its the end pipe that makes it so loud as well apparently...
oh well i didnt like the exhaust anyway i thought it looked ugly. Going to put something nice a polished and shiney on it once we get pass this EPA thing.
inark
i have a cat back HKS system, but recently replaced the rear canon with the standard muffler, i.e had an 's' pipe made to fit the standard muffler to the 3 1/2 inch HKS pipe and the results were amazing....took it from 100+ db to 84 db ......
so the rear muffler determines the loudness is my point.
I got done too.. EPA sent me a nice letter to tell me mine was too loud... pfft..
I didnt think mine was that loud...
Got it tested on Friday.. and its 95db.. :P
They are going to put a smaller resonator (spelling) on it :)
replacing the 3' with a 2'.. they said it shouldnt restrict it too much... What do you guys think???
permanently? i don't like it. That means you're effectively reducing the entire exhaust to 2". Get a 3" straight through resonator or a 'daalder magic resonator" (still 3") and get that put in the system under the car. That should bring 95dB down to 89.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
