Wrecking an R32 GTR, motor has done a bottom end so will be selling all parts seperately.
6 speed manual R34 GTR Getrag ?
HKS 4" High power exhaust pipe $500
TRUST front pipe $200
Greddy GTR aluminium radiator $650
Aragosta Coilovers $1000
NISMO arm set
ATS LSD $800
AW Work mister S2R 9J-17 $1500
TRUST front bumper
Carbon bonnet $750
N1 light and HID 6000 Kelvin $700
R34 GTR Vpec Turbos ?
Exedy triple clutch $1000
R34GT-R aluminium pedal $150
Kansai Front and rear tower bar $300
Shell will also be for sale last of all. All other parts available can send interstate.
  • Replies 44
Can organise pics but most parts are still on the car so will take a week or two to get some it all off.
Havn't put a price on the Getrag as I'm struggling to find what they sell for? I've found them new in Japan from a seller on the net for $9500 so whats a used one worth? I'm happy to take offers.
I mainly deal in S13s so some GTR stuff is foreign to me. Can someone tell me how to tell the difference between 32 and 34 dump pipes?
32 dumps belong in the bin (seriously), 34 dumps would be worth about $100 or so
Getrag pricing is more interesting as there's aftermarket options that are quite well priced around the 5k mark. There's 2 OSGiken boxes for sale currently and they both have no interest at 4k. With that said id expect a price of about $2500ono on the getrag, otherwise people will go for the OSGiken boxes which are widely accepted as "the" box to have in your GTR. The last getrag i saw for sale sold for about 3k and was pretty much new, that was a while ago now
Once you've made up your mind about the price please let me know :)
Hi mate, interested in the HKS 4" exhaust, is it stainless steel or cast?
Also, does it have a mid muffler or just the end cannon? Pics please if you can.
Cheers,
Simon
Cheers,
Simon
Oops I meant does it have a mid muffler or just 4" straight piping with an end cannon.
Thanks,
Simon
I Paid a fair bit for my getrag about 3 years ago.. but it does have a larger spline than stock.. they'd still chase a bit of money but would be hard to move.
sell the tail shaft, cross member, clutch slave, clutch cable all in one for someone with a r32.. they support some pretty big power and would suit someone with around 300kw otherwise... someone buy my damn os box :yes:
I'll take the front and rear tower bars if they fit over my turbos, and can do pickup as I live in Adelaide.
I know a couple of guys got in earlier but if it's easier for you to sell locally then I'll put my hand up.
Interested in the Getrag too. PM me your details and I'll come over for a chat.
sorry off topic but why are you parting the whole car just because its done a bottom end? does the r34 box come with everything needed to fit it to the 32?
cheers
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
