Sorry to anyone I havn't gotten back to need to pull things off and organise pics etc.
Wrecking as the car was needs an inspection etc and I can't justify putting a new motor in and trying to sell the car complete with the market for used cars as it is right now.
  • Replies 44
Like I said before I'll take the front & rear Kansai strut braces if they fit over my high mounts, and I'm in Adelaide.
If you'd prefer to deal locally rather than post, please PM me your contact details.
I might be interested in the Getrag too. Anyway, shoot me your contact details and I'll come around for a yarn.
Nismo arm set consists of Rear camber arms, rear lower control arms, rear traction arms, front upper camber arms. $220 per pair or $800 for the set of 8 pieces.
Interested in varoius parts and I'm in Adelaide please contact Mark : 0429 606 894 because you have not repied to the Pm I sent.
Cheers
Wrecking an R32 GTR, motor has done a bottom end so will be selling all parts seperately.
6 speed manual R34 GTR Getrag ?
HKS 4" High power exhaust pipe $500
TRUST front pipe $200
Greddy GTR aluminium radiator $650
Aragosta Coilovers $1000
NISMO arm set
ATS LSD $800
AW Work mister S2R 9J-17 $1500
TRUST front bumper
Carbon bonnet $750
N1 light and HID 6000 Kelvin $700
R34 GTR Vpec Turbos ?
Exedy triple clutch $1000
R34GT-R aluminium pedal $150
Kansai Front and rear tower bar $300
Shell will also be for sale last of all. All other parts available can send interstate.
Mate
Intereseted in the getrag.
What condition is it?
does it have transfer?
what sort of price are u asking?
thanks
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
