This is a list I found on skylinesdownunder regarding R33 paint colors:
AN0 Super Clear Red
BN6 Beep Marine Blue
KH3 Black
KL0 Spark Silver
KN6 Dark Grey
LP2 Midnight Purple
QM1 White
KP4 Sonic Silver
AR1 Super Clear Red 2
Does anyone here have a Silver or Grey R33 that they have pictures of, so I can compare and determine what color mine is (it's on a dock in .jp and the supplier can't get to it to tell me).
I'm looking for KL0, KN6 and KP4 colored R33s.
Thanks,
Jason.
https://www.sau.com.au/forums/topic/25453-r33-paint-colors/
Yeah, this is the info from http://meggala.com/r33option.html :
The SII R33 range came in 6 standard colours (not sure on the GTR?) I even have the paint codes
White - QM1
Red - AR1
Black - KH3
Blue - BN6
What looks like Graphite - KN6
& Silver - KR4
I dunno' what the actual Nissan names are for these colours, cause I can't read Japanese I don't have the paint info for the SI range
I've confirmed two people who have the KR4 paint, and I'm hoping the R33 I've just paid for is the same!
https://www.sau.com.au/forums/topic/25453-r33-paint-colors/#findComment-540861
Apparently it has some hks gauges (the guy could tell from the photo) and that was it.
Although, looking at the rear end photo, it does look like its had a non-standard zhorst fitted. I was told that it only had the rims and gauges originally .. will just have to wait and see!
https://www.sau.com.au/forums/topic/25453-r33-paint-colors/#findComment-541008
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
