hello Just a quick question,
does any 1 know if the R34 neo injectors use an EV1 or EV6 style connector?
lastly can any 1 confirm if a a stock injector has these dimensions
inlet (top) to suit 13.5MM fuel rail (when o ring is compresed)
bottom to suit 14MM intake ( outside OD of Oring =15mm when not installed or compressed)
total length of injector 74.8MM
i am planning to use a siemens deka 610cc injector if all works, as there cheap and commonly used in XR6 turbo's (BF's)
Regards
Chris
https://www.sau.com.au/forums/topic/254726-r34-injectors/
  • Replies 138
What drop in replacement injectors are there for the Neo engines? Will GTR injectors fit?
Injectors in my stag are pretty close to maxing at 320awhp and a mate has some 550cc gtr style injectors I could get for cheap cheap..
https://www.sau.com.au/forums/topic/254726-r34-injectors/#findComment-4397493
ive been thinking of having a play with these as both are hi impedance, the plugs are differrent and im pretty sure the tops are larger on the XR6 injectors... so not drop in though.
hey the plugs dont really matter too much from what i have noticed as u can buy pigtails to convert or replace completely. yeah these injectors are a 14mm inlet. no idea what the stock inlet is or the total length.
ps i don't wanna pull all the gas injection crap off to get to the petrol 1's untill i really need to.
i mean u can pick up a set of seimens injectors for $450. i read some were that a spacer is all that is needed to fit them, but this doesn't sound correct to me.
http://www.bmotorsports.com/shop/images/MO...imensions_a.JPG
http://www.bmotorsports.com/shop/images/MO...imensions_b.JPG
full copy and paste
Genuine Siemens / Mototron DEKA IV High Impedance Injectors
These injectors flow 60 lbs/hr at 43.5 PSI ( 3 BAR ) and up to 85 lbs/hr at 87 PSI! In addition, these units are high-impedance. Despite the high flow rate, they are linear and controllable at low pulse widths and have been used in ULEV applications! This allows you to use a larger injector than normally possible without hurting idle and low speed driveability. Adding to the flexibility of application, these units are high-impedance; making them compatible with most ECUs, while delivering the most flow available in a High-Impedance injector.
These injectors are able to function at high fuel pressures and don't exhibit the high fuel pressure handling problems found with many other high flow high-impedance injectors. This makes these injectors very well suited to turbocharged and supercharged applications that see high fuel system pressures.
Engine performance and running quality are enhanced through the optimized spray pattern. Unlike competitors "pencil stream" high flow injectors; these High Flow injectors utilize a multi-orifice tip providing a true 30 degree spray pattern for improved mixture preparation. This results in lower BSFC and better idle quality than many injectors with less flow.
FEATURES:
  • Genuine, reliable Siemens Injectors
  • Excellent response characteristics
  • Robust Design
  • High Impedance
  • Low Impedance performance characteristics with High Impedance Compatibility
Specifications:
  • Coil Resistance: 12.5 Ohms / High Impedance / High-Z (No ECM driver modifications required)
  • Static Flow Rate @ 43.5PSI ( 300kPa ) w/Gas: 60 lb/hr = 630 cc/min = 453 g/min
  • Static Flow Rate @ 87PSI ( 600kPa ) w/Gas: 85.7 lb/hr = 900 cc/min = 648 g/min
  • Gain: 0.11ms/mg
  • Offset: 0.055ms
  • Turn on time @ 14VDC: 1.14ms
  • Turn off time: 0.85ms @ 600KPa
  • Connector: Bosch EV1
  • Orifice Type: Multi-orifice
  • Spray Pattern: 30 Degree Spray Cone
  • Factory fitted with Viton upper and lower o-rings
Equivalent Part Numbers:
  • Siemens FI114961 or 107-961 ( 107961 )
  • Mototron INJ-GAS-006 ( L107)
  • Accel 74620L
  • MSD / Edge 2030
MATING PARTS:
For Mating Sensor Connector Pigtail, see:
For Mating Sensor Connector Kit, see:
For Mating Connector, see:
For Mating Terminals, see:
https://www.sau.com.au/forums/topic/254726-r34-injectors/#findComment-4398848
also curious to know which injectors will drop in fit in 34gtt.
Go on any trader websites, they usually tell you, or just ask them.
urtwhistle- my injectors are highflowed to 555cc, there a company in oz that does it, think its German, forgot the name of the joint though :(
https://www.sau.com.au/forums/topic/254726-r34-injectors/#findComment-4406192
I bought new big injectors for my RB30, don't want to do that again for the Stag so that's why I would like to find a DROP IN REPLACEMENT from an OEM application.
Nismo do a drop in replacement for the GT-T. These are 440cc's, running them in my 34 at the moment, got them 2nd hand as well so a couple of hundred off retail. Pays to shop around on the forums :D
https://www.sau.com.au/forums/topic/254726-r34-injectors/#findComment-4406615
Nismo do a drop in replacement for the GT-T. These are 440cc's, running them in my 34 at the moment, got them 2nd hand as well so a couple of hundred off retail. Pays to shop around on the forums :)
I'm trying to figure out if there is an OEM alternative, i.e. like S15 injectors for normal RB25 or RX7 injectors etc etc
I have already spent nearly $1k on injectors for my RB30 and don't want to do that again when I only want to squeeze another ~80hp out of the Neo engine!
https://www.sau.com.au/forums/topic/254726-r34-injectors/#findComment-4407103
?? NISMO - Nissan Motor Sport OEM supplier, so direct fit for R34GT-T.
I'm not trying to pedal anything, just saying that that bloke made a mistake when he said that R34 NISMO injectors were 440cc that's all.
I'm not trying jam them down anyones throat, just trying to help out with some options. :P
https://www.sau.com.au/forums/topic/254726-r34-injectors/#findComment-4407874
i understand what both of you are saying. what i'm trying here is to work a nice cheap simple upgrade. due to R34 injectors being top feed and also the long pencil style it makes upgrades that touch more limited and expensive. If these seimens injectors work with out much trouble it will also mean that FORD MOTOR SPORTS injectors (come in the typhoons), BOSCH 968's (cheap common upgrades for XR6T's) and generally alot of other cheap oem common parts can be thrown in.
some times we need to think out of the box or we forever will just be screwed over with limited choices
chris
https://www.sau.com.au/forums/topic/254726-r34-injectors/#findComment-4408574
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
