not sure if anyone has seen these parts before... but i visited their shop today and was surprised they make these so cheap:
http://www.vivagarage.com.au/nissan/stagea..._aeroparts.html
Make sure you check the Nissan - Stagea links up the top, because there are more parts available. I had a good look at their R34 stagea today. Looks the goods!
Nigel. SA
https://www.sau.com.au/forums/topic/254842-stagea-body-kits-cheap/
Nigel. SA
nice find....the 34 front looks good...wonder how much labour is to fit it.
More to the point, how much do the rest of the parts cost.. they only list the front bar and fenders... not the bonnet, the hinges, the bonnet latch the headlights the headlight brackets and the radiator support
Got abit excited when it seen the R34 conversion kit and then remembered R34 non xenon headlights are around $1000 a pair then around $2000 for xenon head lights.. bonnets are only $100 for a second hand one so the conversion would be relatively cheap apart from the damn headlights :)
Edited by SHIZNT
Picked up my type M front bumper on Thursday. Currently getting it fitted to my Stagea as we speak, holes are not pre-drilled. Friendly service at Viva Garage and they love to talk about the stags. Once its fitted correctly, I pull it off again for a light rub and spray. :ermm: Just in time for the car show next weekend.
Will post pics when done ... and if it ain't too hot. :banana:
Here's a very rough chop..
Trying to decide do I save my money and slowy buy parts to do a R34 front end conversion and just continue taping the cracks in my bumper.. get another Nismo look alike from Monkey Warehouse or get a Vivgarage Type M bar..
Do the Viva, I like the look of those kits (Masa) I am planning on getting one for my s2 stag. Plus there looks to be quite a bit of meat on the bottom part of the front bumper so i imagine it would hold up reasonably well. Looking at your nismo front bumper it doesn't look like it would take much to damage that.
Got abit excited when it seen the R34 conversion kit and then remembered R34 non xenon headlights are around $1000 a pair then around $2000 for xenon head lights.. bonnets are only $100 for a second hand one so the conversion would be relatively cheap apart from the damn headlights :P
Where do you find s/hand genuine alloy r34 gtr bonnets for $100. :P
R34 GTT bonnets will not suit.
Pretty sure r34 zenons are about $1600 EACH new.
I would also question the fitment quality of copied Masa R34 guards from Viva. If they have not re-shaped them and just taken a mould from the original Masa guards they would fit even worst.
I have a genuine set of Masa guards and they do not fit perfectly and will be scrapping them soon for some re-worked CCubed copies.
hey Jay .... wasnt that the bumper the caryard had on previous ?
Kinda looks the same but the bar the caryard had on it was a Abflug bar.. there rare as hensteeth to find and are over $1000 for a new one from Abflug in Japan then you have nearly $800 for postage ontop of that..
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
